3800 INTENSE MPS systems are out
J/O always good at summing it up w/ the smilies.
this thing looks sweet
Looks just like the other pulley systems out there
It was designed to actually fit the ribs of the belt properly
Have you been seeing alot of belt slip or damage w/ your ZZP system???
The pulleys are also compatible with the ZZP hub
Maybe because its the same damn thing.
Intense is really stepping up this year with products.
Maybe w/ other products but I wouldnt call this really stepping up.
Next week it will be,
INTENSE released thier new LS1 TB
* 85mm LS6 MAF sensor
* LS1 throttle body with nine* custom modifications for use on the Grand Prix
* Rubber boot to connect the throttle body to the Mass Air Flow (MAF) sensor
* Throttle Position Sensor (TPS) adaptor harness
* Three M6-35 metallic red* socket head bolts
* Custom adaptor plate to mate the M90 to the LS1 throttle body
* Two M6 stainless bolts for throttle cable bracket
* Custom throttle cable bracket
* OPTIONAL TechEdge Mini-AFC 1.1 or TechEdge Mini-AFC 2.0 custom calibrated for the LS1 Mass Air Flow (MAF) sensor slope and also allows you to calibrate your air/fuel ratio for any injector size
* Chrome crankcase breather cap
* All necessary hardware needed for install
Fish
From the quiet street
40,587
7,999
Hanover Park
Fish
Dont worry. Im sure ZZP will have their "Bullit proof" trannys and racing blocks out soon too. :rolleyes: :rolleyes:
gtphale
1,578
Pulley systems are all very similar. There isn't a whole lot of differance. Zoomer and ZZP followers are pissed cause Scott came out with a product similar to Zoom's. Well its a smart move by Scott and a bad move. Smart cuase now people with a ZZP modular can run Intense pulleys and bad cause Intense modulars can run zzp pullies. I for one wouldn't remove and sell the ZZP one to run an intense one there just isn't a differance in the hub except for what its made of and its polished look. Put a pulley on it and you don't see the hub anyway.
With the split of both company's they will be coming out with alot of similar products they both did a lot of research together and had alot of ideas they shared.Scott needed to make a pulley system so he choose the one that made most sense. Zoomer is just pissed cause now people with the hybird 112 can run an intense pulley system and that irks him. Is Scott supposed to tell people that buy a mp112 kit togo and buy a ZZP pulley system? Don't think so, I think its a great move and can't wait to see the tb that instense comes out with.After all where do you think Zoomer is getting his trans info from? His own R&D I don't think so.
98 TGP TOY
2,167
Morton, IL
gtphale has some good points. Everyone just needs to realize that while the two companies were together, there was no need for them to each make the same product. Well now that they split, they want to bring their shared products to market. So the company that didnt get claim to it when they were together, is now making their own. I just hope that when the companies start doing R&D, that they hadnt done when they were with eachother, that the other company doesnt copy it and sell it.
