Garage full of stuff
BumpinGTP
South Suburbs
I would highly prefer pickup for all of this stuff simply because it would be way too many shipments to keep track of but if absolutely necessary I will ship. I am moving soon and want all this stuff gone before I move.
Intense oil restricted pushrods - $50
Comp Cams steel retainers (new)- $25
SS grilles - $100
SLP powerflo exhaust - $300
Speedbuilt rear STB - $70
3.69 reluctor wheel (new)- $40
99+ K&N panel filter - $20
L67 flexplates - $20 each
Caspers VC breather - $25
Stock valve covers - $50
Stock heads - $50 each
M90 boost bypass - $35
99+ MAF sensor - $35
Stock injector set - $70
Grooved idlers - $10 each
Oversized tensioner pulleys - $10 each
Stock manifolds - $30 set
L36 lower intake - $40
Stock foglights - $5 each
Trans dipstick tube and dipstick - $20
Oil dipstick tube and dipstick - $20
Stock cams - $10 each
97 GTP fuse box - $35
Stock valvesprings - $20 set
Autometer Carbon Fiber trans temp gauge - $25 w/ no sending unit
Ractive exhaust tips - $50 (these look identical to the SLP trapezoid tips)
Viton valve seals (new)- $15
Stock oil fill necks - $5 each
Stock rockers - $25 set
99 PCM - $50
00 PCM - $50
Trans lines - $30
Differential cover - $35
Thermostat housing - $10
16' 4ga power wire - $25
99+ F duct - $10
Stock plug wires - $3 each
Oil filter adapter - $15
Timing cover - $35
Oil pan gasket (new)- $20
Camshaft bolt (new)- $5
Flexplate bolts (new)- $5
Crankshaft bolt (new)- $5
Rear cover gasket (new)- $5
Metal front cover gasket (new)- $5
Stock lifters - $5 each
gtphale
Paul still hasn't PM'd you about that bracket? Maybe i'll just pull if off not like he would know its gone. LOL You can just come pick it up. Paul you better speak up if you want this gone or not. Last I talked to him he said he PM'd you already.
Oh and i'll take the seals. We'll have to set something up and I'll met up with you over the weekend how does sometime sunday sound?
BumpinGTP
South Suburbs
any chance you have a W body ac compressor bracket?
[/b]
99% sure I do, let me double check tomorrow.
[/b]
Give me a call later this week.
smknL67
Bensenville
I'm interested in your '00 pcm. How far away are you from downtown Joliet? pm me your address I will be out there collecting rent next saturday or sunday
I
imported_Ron Vogel
I definately want the timing cover, may need a few more things too. I'll give you a call towards the weekend.
Mike K
Forum Sponsor
Ron, FWIW the engine I have sitting here for you has the timing cover on it...
I
imported_Ron Vogel
Oh, ...Sorry Steve!
I may want some of the bolts, I just need to take stock of what I have!
BumpinGTP
South Suburbs
Yes, but it would only be good to use for a core charge, it is locked up. I actually need another for the car I removed this one from. Sorry John.
cpk71
elmwood park
<div class='quotemain'>
It is option B here...
http://www.pfyc.com/pc/GP5003/GPEXH/SLP+Po...Grand+Prix.html
[/b]
I'm waitin for my tax return so I dont have the cash now but i could use it ,I'll get back to you if i get it but if someone has the cash go ahead and get rid of it. thanks chris
[/b][/quote]
I 'll take it if it's still available Give me a call 1708 935 7757 i' like to come look at it . I'll bring loot i also need a drivers door panel if you have one lying around i need the top plastic piece later chris
