3800 FS: Casper's Timing Commander
Mikes1998GTP
Xenon Powered
Mar 12, 2008
443
Phoenix, AZ
--Plug-N-Play - Plugs right into your IAT harness!
--Easy to use - No need to know what temperature equals what timing; gauge tells you how much timing is being added/ pulled!
--Fits in standard gauge pod
Are there any other modifications required to run this? - Yes. As with all timing adjusters you will need to have the adjustable timing table in your PCM. This can be accomplished easily with a PowrTuner and the included instructions or by ordering a DHP PCM with adjustable timing values.
Sells for $99.99, On Sale for $59.99 plus s/h. Local Pickup near Aurora, IL will also be considered or if you will be at Friday's Meet, lemme know if you want me to bring it with to check it out, thanks!!
(timing commander picture from WBS)
  • M
  • 3
  • 586
