FOR RENT: Motive Brake Bleeder
greasy
LTTR BOX
The Litter Box
I bought a Motive Brake Bleeder to do my brakes and the thing kicked ass. It is not something you need to own, but it makes doing a full flush really easy by yourself. If this is something you want to use, I'll let you rent it for $10. If you have a later model Ford you will not need any adapter for the unit, but if you have a different make you will need your style adapter for the brake fluid resovoir.
wombat
Wood Dale, IL
[MENTION=60]greasy[/MENTION]- will this work for a Cheby? [MENTION=73]tinfoilhat[/MENTION] needs to bleed his shit.
Thirdgen89GTA
Buffalo Grove
This would certainly be easier than the MityVac hand unit I have for bleeding.
With that, I have to remember to top off the reservoir or its possible to run dry. Not usually an issue, but if you are flushing a system its possible to forget to watch the level.
greasy
greasy
LTTR BOX
The Litter Box
With the appropriate adapter, yes. Let me know what car and I'll tell you what adapter to buy.
Thirdgen89GTA
Buffalo Grove
Also how does this thing work
It seals the master reservoir and pumps pressurized fluid into it. Then you crack the bleeder at the end your are bleeding and it will keep the master full while it flushes out the line.
Its a lot like a gravity bleed, but faster.
If you have time on your hands to sip some lemonade you can pull the cap off master, top it off, crack the bleeder, then sit on your but until gravity and atmospheric pressure flushes the brakes for you. It just takes a long time.
greasy
greasy
LTTR BOX
The Litter Box
Chevrolet/GMC/Buick/Cadillac/Pontiac/Olds (GM) Prior to the 2000MY most GM products used a rectangular or oval shaped cap on a wide mouthed reservoir. From the early 70s to mid 80s the reservoir was metal, after that time period it was plastic. If the reservoir is less than 3.75" x 6" the 1105 adapter will be needed which comes with kit 0105, if larger than 3.75"x6" the 1115 adapter in kit 0115 will be needed. In the late 90s GM began switching to a round twist to lock cap across all product lines. The cap twists 1/4 turn and has 3 locking tabs on the underside. Cars with this type of adapter will use Power Bleeder p/n 0108 or the Black Label 0118. The corresponding adapter would be the 1108 or the metal version 1118. If you have late model a Pontiac GTO AND G8, please call us as it seems Pontiac was using random reservoirs on the GTO AND G8. The G8 primarily uses the adapter 1117. But the 1118 has been seen- The GTO has seen the 1117, 1118 and a select few that use the 1105 adapter. Note some Saturn cars use a different cap. - please see the section on Saturn below.
greasy
greasy
LTTR BOX
The Litter Box
I forgot to mention I also have a catch bottle for the old fluid too, makes everything simple and clean.
Primalzer
Damn, if I was keeping the CV any longer I would've done this...I'll ask my buddy, and see if he wants to try this with his VW
greasy
greasy
LTTR BOX
The Litter Box
Yup in Hanover Park right off of Schick & County Farm Road.
tinfoilhat
Riding the Hubble
Can I rent this from you possibly this weekend? The adapter and liter of dot 4 should be coming in Saturday
greasy
greasy
LTTR BOX
The Litter Box
I will be out of town all weekend at a hockey tournament. Unless you pick it up tomorrow by 11AM you will have to wait. Also I am giving the extra brake fluid to Bru since he committed to renting already. I will need it back for [MENTION=12]Bru[/MENTION] by the 19th.
tinfoilhat
Riding the Hubble
Available tonight for a quick stop by?
tinfoilhat
Riding the Hubble
You can come anytime before 7 or after 9:30, I have a hockey game tonight.
Sweet. After 930 works for me. Ill pm you my cell, if you wanna text me when you are ready after the hockey game then ill head towards you.
Turtle
Is the adapter 107?
What's the status of this rental? Someone has it or is it free to rent.
Not happy with my pedal feel right now.
greasy
greasy
LTTR BOX
The Litter Box
Is the adapter 107?
The adapter depends on what car you have. The rental is not free, it costs $10 to rent. [MENTION=12]Bru[/MENTION] has it right now, but he is done with it.
Turtle
I know it's $10. What I meant is if it's free as if no one has it right now.
This will be on a Nissan, which I've read works with the Ford 3 prong/ 107
greasy
greasy
LTTR BOX
The Litter Box
Ahhhh I gotcha, sorry I just woke up when I responded. Not sure if the 107 works with late model Nissan, very well it could though. When I get it back from Bru you are welcome to it.
Where do you live?
Turtle
I'm in the city. Work in Deerfield.
If it's the 107, I'm like 95% it will work according to forum postings.
