fbody passenger side throttle body intake ?
02BlueGT
No Fucks Have Been Given
Feb 21, 2008
9,922
18
Now apearing in Hanover Park
You need a custom fuel rail, as the score ones will not line up and the na ones are smaller with a for that cannot be used with boost. I believe that zzp makes a L36 fuel rail for boosted applications, or you could always make your own.
The TB cable might need to be extended depending on your turbo placement......
The LIM needs to be changed to the f body l36 LIM to match the ports from the UIM. But the f body LIM will bolt right up to the L26 heads and series II/III block.
The batterY and fuse box will also be in the way and need to be moved/modified.
Im sure there is more
  • 1quick
  • 1
  • 380
