Fbody and Wbody parts (headlights, stock parts, Loudmouth, Air compressor)
And more! All prices are OBO. Posting everything here first and then if there are no bites will head to the make-specific forums. Can provide more details and pics on everything. I store these parts at my mom's and she's putting the house up for sale. I don't have a garage spot at my place so everything needs to go!
Fbody
1998 complete manifolds, cats, y-pipe and EGR/Air system sold
SLP Loud Mouth Gen I catback. Was cut up for removal Sold
Fbody stock rear LCA (pair) $50
LS1 intake manifold - $150
LS1 stock injectors - $50
4L60E stock torque converter - $80
Stock fbody fuel pump and assembly- $30
1998 stock torque arm $30
Wbody/Grand Prix
Grand Prix Projector headlights $70
Stock GTP stereo $20
9-inch K&N cone filter, needs cleaning Part RE-0870 $10 - Pending
L67 Exhaust manifolds $70
Stock rear sway, upgraded front but ears are starting to crack $20
Miscellaneous
Pennzoil and Checkered flags, new. Great for garage $10
Bru
10,220
Air Compressor.... It works? Anything wrong?
I bought it from Ron Vogel a few years ago and only used it twice. It blows the breaker in the garage so it was a hassle to run the cord to the basement. I never used it more than twice. I'll try and find his original for sale thread with details.
interested in the GTP black headlight housings, do they come with the corners also?
Sure does. Here's what they look like installed. I can get some close ups if you want. There's some goop visible from when I sealed them up but you'd probably need to remove that and re-seal them since they've been sitting so long.
Bru
10,220
Projector low beams and reflector high beams. Yup, they have halo rings that illuminate when tapped into the correct wiring.
They need some work to reduce bounce. The housings are cheaply made and without support they bounce. It's a well documented problem on the GP boards with the first batch of these. There are solutions but I never got around to messing with them.
http://www.clubgp.com/newforum/tm.a...unce&language=single&tmode=&smode=&s=#4421712
Bru
10,220
Inlet size on the filter?
Also interested in air compressor and hose if sinister backs out
Here are the filter specs. Unfortunately there's someone else in line for the compressor before you, Adam. I'll let you know if both back out.
Part RE-0870 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 6 in (152 mm)
Flange Inside Diameter: 4 in (102 mm)
Flange Length: 1.75 in (44 mm)
Flange Type: Centered
Height: 9 in (229 mm)
Top Outside Diameter: 4.625 in (117 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Material: Cotton Gauze
Flanges: 1
Filter Re-Oiling Amount: 1.87 oz (55 ml)
Weight: 2 lb (0.9 kg)
Product Box Length: 6.31 in (160 mm)
Product Box Width: 6.31 in (160 mm)
Product Box Height: 10.75 in (273 mm)
