If there's anyone in Illinois or the surrounding area that changes the lug pattern on axles I sure couldn't find em. Back in the day this would have been roughly 100 bucks. I'm too cheap to get a set of axles for 400 bucks if I don't have to so I'm going to give a shot on my own.
I popped the studs out and cleaned the holes of their rust.
I then used an old PC heat sink and a copper block to weld. The foil is to protect my bearings. They're original but in good shape so if I can avoid the labor to replace I'm okay with that. I'm not into replacing stuff that I don't need to from a cost and labor perspective. Just doesn't make sense to replace working bits.
The first set of welds post copper block. Wasn't super satisfied with the penetration so I welded up at the face too.
Here's the face post weld and grind. Not going to say it's pretty but it's pretty darn flat. Should be ready for drilling when I get my jig ready.
Here's a pic of the jig.
daturbosix gave me a brake rotor from his junk pile. I think it was a Jeep if I had to guess. It took a decent bit of work with an angle grinder and some 80 grit on the center bore to make it into this drill setup. If I had to do it again I would cut the rotor face off with more of the "hat" there so I could chuck it up in the lathe and turn the 20 thou or so out in 30 seconds.
You can see how much I'm going to have to modify the holes. I can't just rotate the pattern because there's a hole to unbolt the axle shaft there. I trust plugging the 5 holes way more than I trust making a plug and welding it in.
Drill bit's on the way for the wheel studs. Need to make a jig for the pilot bit, that'll probably be some Atlas action. Also need to see if I have a big enough diameter chunk of stock to do it with. I should be able to figure something out.
