đź“° Auto News Edmunds Full-Test - 2011 BMW 1-Series M
118,998
Is 1 Greater than 3? Maybe Just This Once
Launching out of slow corners is where the 1 Series M excels.
By Josh Jacquot, Senior Editor | Published May 31, 2011
Here, on Willow Springs Raceway, the self-proclaimed "Fastest Road in the West," that our mind begins to wander. Even though we're ripping through Turn 8 at 121 mph in the 2011 BMW 1 Series M Coupe, it's hard to concentrate.
"Are these wheels forged?"
"Did I lock the house this morning?
"Only one day until the rapture? Really?"
"Man, this thing has a lot of grip."
The last thought hangs around for awhile, mainly because it's this car's grip — more than any other M car — that defines it. We're not surprised, as it wears the same set of Michelin Pilot Sport PS2 tires included in the M3's Competition package. More importantly, those four generously sized contact patches support only 3,346 pounds, about 210 fewer than an M3 Coupe.
BMW says the M3 represents everything the company understands about driving dynamics. But the 1 Series M Coupe is half M3 — utilizing not only its tires but also its suspension hardware, brakes, steering rack and more.
Its attitude, however, is different. Still, this is a proper M car.
Subjective Feel
Back roads like this one will favor the M Coupe over an M3.
By now you probably know the 2011 BMW 1 Series M Coupe shares its engine with the Z4 sDrive35is convertible — a machine so poorly named we often forget it exists. But the engine's source and origins are far less important than its numbers and its influence over the M's chassis.
Here the 3.0-liter twin-turbo inline-6 is rated at 335 horsepower and 332 pound-feet of torque, which is sent through a six-speed manual transmission only. Also, because big surges of torque are quite enjoyable, the M-specific engine calibration allows a 5-7-second overboost. Our own internal testing shows it's quite effective.
The question, given the numbers at hand and the hardware at work, isn't whether the 1 Series M Coupe is a proper M car, but rather how does it stack up against the M car — the current-generation M3? When it comes to sheer perception, the littlest M gives up nothing.
In fact, some purists — particularly those who have been whining about the M3's curb weight since it first hit Internet forums — will likely find the M Coupe to be the perfect compromise. Driving the two cars back to back on the 2.5-mile Willow Springs road course, there's little difference in peak speeds on the circuit's front straight.
M3 Heart
Power delivery from the N54 mill is familiar.
Although the 2011 BMW 1 Series M Coupe utilizes the M3's aluminum subframes, control arms and links, it lacks that car's Electronic Damping Control. In its place are conventional (aluminum) dampers. BMW, however, refuses to release any information about the M Coupe's spring rates or additional chassis stiffness. There are new gussets surrounding the shock towers under the hood, and the lack of a sunroof no doubt stiffens its chassis relative to the standard 1 Series cars, where it's standard equipment.
This isn't the raw, instant, shrill explosion of sound and revs we've become accustomed to from BMW M cars. But it gets the job done. The 1M also shares the M3's steering rack, which at 12.5:1 is among the quickest-ratio racks on any production car today. Combine that with the M Coupe's 104.7-inch wheelbase (4 inches shorter than the M3) and this car is, well, lively. And by lively we mean reactive, snappy, punchy and fun. There's even an "M" button on the steering wheel, but on the Coupe it only bumps up throttle response.
It's a concentrated dose of M3. Drink plenty of water.
A Unique Machine
Keeping it in its lane is easy. But go easy on the gas.
Driving the M Coupe on one of the country's fastest road courses didn't tell us much about its best properties. Those we discovered later, as they're best explored below 80 mph.
This car's explosiveness out of low-speed corners is as fun as it is frantic. It leaps from tight-radius bends as violently as any two-wheel-drive car we've ever driven. It's very controllable, but it's not for beginners. This coupe reacts quickly.
It's the only car that's ever made us want to autocross. With all its wide-bodied, fat-tired, short-wheelbase torquey-ness, the 1M is perfectly suited to slipping between cones on the clock. It might even make that lame form of parking lot racing fun.
Objective Data
Conventional dampers and steel springs keep the 1 Series M level while cornering.
At the track, our subjective impressions are rapidly verified as the M brand's little hammer pumps out big numbers. Sixty mph disappears in 4.6 seconds (4.4 seconds with 1 foot of rollout like at a drag strip) and the quarter-mile is gone in 13.0 seconds at 107.7 mph. That's identical to the last M3 Coupe we tested to 60 mph and only two-tenths slower in the quarter-mile.
But the real story, the one that should make you plead for this car, is the way it handles. It's the kind of intuitive-feedback, butt-connected-to-the-contact patch sort of feeling we wish were available in everything we drive. And it's immensely fun.
Given the N54's propensity to pump out huge waves of torque, the relatively short wheelbase and the M3's viscous limited-slip differential, there's a sense of necessary hoonery built into the 1M.
Around the skid pad, this means there's no problem steering with the throttle. And the gap between the limit of grip and limit of control is a big one. Go ahead, slide it all you want; that's what it's for. Keep the rear wheels behind the fronts and it will produce an impressive 0.96g — better than the M3 (0.95g). Slalom speed, at 71.4 mph is similarly impressive, although not quite as good as the M3 (73.3).
Braking from 60 to zero, given the M Coupe's M3 brakes (14.2-inch two-piece rotors and huge sliding calipers up front) is an effortless endeavor. Heat capacity and feel are appropriate for a genuine performance car. Oh, and it stops in only 106 feet — a foot shorter than the M3.
Other Details
Black Boston leather is the only seat treatment available on the 1 Series M Coupe.
BMW has figured out the key to making a relatively Spartan interior look appropriately unique. A large part of the secret is the utter lack of reflective materials. Yes, there's a satin-finish bezel here and there but this is largely a matte-finish interior. The special part comes from Alcantara suede on the shifter and parking brake boots as well as on the doors, dash insert and instrument panel shade.
Black Boston leather is the only finish available on the 14-way adjustable seats, which along with the Alcantara bits are stitched in orange — a small detail that is tastefully striking. There's also a thick-rimmed, leather-covered steering wheel that seems perfect for directing this angry little pug.
The Deal
The M Coupe is wide and mean. No arguing that.
BMW tells us it plans to sell only 1,000 M Coupes in the U.S. this year. It's likely there will never be more. They start at $47,010 including destination fees, which might seem steep until one realizes that it offers performance on par with an M3 for about $10 grand less. Our test car, fitted with heated seats, Valencia Orange paint and the $2,400 Premium package, rings up a $49,585 bill.
Gripes? There are few. The engine lacks the character of most M cars. Yes, it's powerful and amply responsive and probably telling of the powertrains to come in future M vehicles. Still, this isn't the raw, instant, shrill explosion of sound and revs we've become accustomed to from BMW M cars. But it certainly gets the job done.
The 2011 BMW 1 Series M Coupe is what purist drivers want: predictable, responsive, powerful and lighter than the only car it was benchmarked against: the M3.
And after 33 laps at Willow and 350 street miles, our wandering mind has reached the following conclusions: The M Coupe's wheels are not forged, we locked the house and the whole idea of the rapture is ridiculous.
Oh, and the M Coupe's grip? Yes, it has more than we ever imagined. And it is good.
These are not forged wheels. But they're huge.
What Works: Purposeful looks, purposeful hardware, purposeful performance.
What Needs Work: Engine lacks the personality of those in other M products.
Bottom Line: A genuinely capable, engaging and entertaining machine that fully deserves its M badge.
Track Test Results
Powerslides are easy in the 1 M Coupe. But you'll need fast hands.
0-30 mph (sec.) 1.9
0-45 mph (sec.) 3.3
0-60 mph (sec.) 4.6
0-75 mph (sec.) 6.7
1/4-mile (sec. @ mph) 13.0 @ 107.7
30-0 mph (ft.) 26
60-0 mph (ft.) 106
Slalom, 6 x 100 ft. (mph) 71.4
Skid pad, 200-ft. diameter (lateral g) 0.96
Edmunds observed (mpg) 20.3 combined
Curb weight, as tested (lbs.) 3,346
As-tested MSRP $49,585
Acceleration Comments - With traction control on and a quick clutch uptake, the car bogs heavily, so I had to feather the clutch on for a decent launch. With T/C off, the opposite is true: It'll boil the tires with ease. It's one of those cars that likes a little bit of initial wheelspin, but going to WOT too soon ends up blowing the run. So, a 2,750-rpm quick clutch, but then patience/prudence is required to maintain ideal traction all the way to the middle/top of 1st gear. Power seems to fade near redline, and short shifting seemed to help rather than hurt quarter-mile time and trap.
Braking Comments - Brakes are nearly fade-free, only varying 2 feet over six stops from 60 mph. Pedal feel is solid and dead consistent; minimal dive and zero wiggle or wander. Noticed some steering wheel shake on the run up to 65 mph, but not under braking. Missing a wheel weight, perhaps?
Handling Comments - "Skid pad: (DSC Off) If I only had feel to go by instead of the electronic timer, I would've guessed about 0.85-0.90g, so imagine my surprise when it posted a 0.96. At this speed, the 1M gently understeers, and trying to kick the tail out with a couple throttle jabs only makes it go wide. While there's no question that the steering precision is there and the weight is appropriate, "feel" is sadly lacking. I never quite know what the front tires are enduring down there and they don't make much noise either. With DSC on MDM, it was actually easier to keep the car nailed to the painted line all the way around.
