Climate Control mounted Gauges
Dasfinc
Ready for the EVlution
Sep 28, 2007
20,919
1,321
Wheaton, IL
Curious if anyone else had done something similar
My ranger has no climate control in it any longer due to the swap, and I was debating about 'gutting out' the controls to use for a gauge pod.
Granted this is not very large, but 'smaller' gauges would work great here.
Has anyone here done something such as this before? There a certain brand that sells good 'small' gauges? The 'small' set 3 sunpro gauges at all autozones would fit PERFECTLY, but they are all mechanical gauges, and I have no need one of the gauges it comes with. Wanted to do Oil Temp, Trans Temp, and then maybe replace the last one with the E-fan switch with a 3 position Dial/knob/rocker *Off/Low/High*
*Not my truck, but for reference*
Bob Kazamakis
I’m the f-ing lizard king
85,581
45,888
Joel
That is the type of thing I'm looking to do :bigthumb:
That's uber easy Dan. Just get some aluminum plate and a hole saw. They also make angled trim rings so you can point them up or towards you. Or I have some carbon fiber you could play with and make your own carbon plate. I made my single din pocket with it. It's pure carbon weave "fabric". You'd have to apply resin to it to make some plate.
