Cleaning aluminum trailer
Broke EF
1,789
4,557
The sticks
I picked up a nice Aluma MC210 trailer last week for a great price. My buddy bought it new, and really didn't use it much. The sticker on the plate was expired in 2014, and the trailer is a 2011 to give you some idea. Anyway, of course it sat outside its whole life and it was under some trees and such. Here is what it looked like when I got it.
At his place
Before I cleaned it at all
And here is is after pressure washing it
As you can see, 95% of it really cleaned up great! The D-rings are all stainless so they are all in great shape. However, you can see in that last pic that the front right deck area is stained from having vegetation sitting on it for years. You can see it here since I was an asshole (really just in a big rush) and never brushed it off before grabbing my mower.
So what can I use to clean that up? I tried simple green, but didn't brush it in at all. Before I do that I figured I would ask you guys whats good on aluminum. Also do you guy suggest anything to get it even better looking and to protect it some?
Thanks,
Sean
Broke EF
1,789
4,557
The sticks
Did you hit it with a pressure washer? Is it mold and mildew? Maybe try bleach or a powdered bleach cleaner like Comet.
Yeah, I pressure washed it with just water. I have a decent pressure washer (Simpson 3200 PSI) and even used the 0 degree nozzle and it didn't make a difference vs the two other wider nozzles I had already used. Then I sprayed it with concentrated simple green, let it sit for a minute or two and hit it again with no change.
Jon01
4,103
15,959
Aluminum wheel brightener, the acid kind works very well on them.
Dilute it down some in a bucket and use a big scrub brush to spread it around the trailer.
Let it soak for 15-30 minutes(don't let it dry) and hose it off.
Aluma's are great trailers, I've had a couple and that's all I will buy in the future.
1quick
26,610
24,225
coal city
If the deck is brushed aluminum you can use toonbright, but don’t get it on anything shiny or it will never be shiny again, it’s an aluminum etching cleaner used on pontoon boats to get the growth off, it will basically look white when your done as it takes all the oxidation out of the aluminum as well so you will want to do the whole deck with it or it will be different colors
stock-t-bird
THORNTON QUARRY
4,362
4,686
Thornton Quarry
same with acid based a/c cleaner...will it clean it......yes....will it brush off the shiny shine...yep
go with some non-acid cleaner..i have some HD/Cleaner non-acid cleaner I can send you for free
you have nothing to lose
its basically a HD non-acid deagreaser used for A/C cleaning...try a small spot for sample..its free dude
shoot me a PM
you have nothing to lose,basically a HD/Degreaser....Environmentaly Safe....i dont see no damage it will do
