car won't start...HELP!
CrunkMaro
DurkaDurkaTerrorist
1979 fiat spyder... car won't start no matter what i do. i'm gettin no fuel no spark no compression.
any ideas where i should start
<3
<3
3800 swap
start with the no compression, verify crank/pistons and cam/valves are moving while cranking and see if it's in time, id rec a leakdown test compression tests only tell you part of the story.
LSx S10
Lombard, IL
<3
What steps did you take to determine you actually had no fuel, spark, or compression?
hellraiser319
Hellraising since 1986
West Bend, WI
No fuel, no spark, no compression, almost seems like timing chain is not doing it's job IMO, depending if its interference or not.
