It's idling real rough, not like it was before I put the mass air flow sensor on but still rougher than usual. During driving it's fine, it's just when the car is in gear and not moving, and when I'm braking, like when the car is almost stopped. There's also a hesitation when I hit the gas when the car is at a stop, assuming this is related to the idle issue. This is slowly getting better though since I put the MAF on so I'm hoping it's just the fuel trims re-adjusting and this will go away, more worried about the temperature issue. Anything in particular I should look for?
What are the fuel trims like during idle? Even a small vacuum leak will peg the FT's.
