C and L intake tube
Brand new in the box C&L Trueflow inlet pipe for 03-04 Mustang Cobra. C&L intake tube goes from tb to maf looks real nice. looking to get around $150 for it.
TrueFlow inlet pipes are now available separately for most popular V8 Mustang applications. These inlet assemblies offer three key features which have made them a very popular bolt-on for use with a wide variety of air meters. The cast aluminum finish with blue silicone hoses really dress up the engine compartment and is much more attractive than the factory black rubber assembly. Due to the fact that these pipes are cast, the inside diameter is consistent all the way through the pipe from the air meter to the throttle body and this is what gives it the name "TrueFlow". By eliminating the flexible ridges in the factory rubber inlet tubes and by controlling the inside diameter for consistency, a modest horsepower gain is achieved.
The new inlet pipe for the 96-98 Cobra Mustang added an average of about 7 rear wheel horsepower over the stock rubber inlet tubing.
Most typical vehicles will receive approximately 3 rear wheel horsepower but several tests have been reported to show as much as 5 horsepower on some applications. For those who are interested in running nitrous oxide, we have cast a special nitrous boss into each TrueFlow inlet pipe to give you a solid location to drill and tap your nozzle into. Due to the fact that these pipes are solid aluminum and are mounted directly to the engine, we do not recommend mounting the mass air flow unit (through a bracket) to the body of the vehicle. When using an aftermarket intake that relocates the throttle body away from the stock position, it may be necessary to make minor modifications for proper fit.
  • TOPGUN
  • 2
  • 233
