Building a turbo/6.0 base colorado in 20 days
118,895
From another forum I'm on. I'll try and piece together all the good stuff.
picked up this here 2005 coloorraydo for 3k
drove over to the scrap yard *collis truck parts*
and picked up a 2006 6.0 out of an express van
for this build since im thinking about keeping it a while, i had someone build a hotside so i could just bolt it in.
Cory Johnson build this masterpiece
pulled the 4 popper and 60e
dropped in 6.0 checked for clearance issues
pretty nice!
junkyard 80e HD2 kit time
slap on PTC converter
drop it all in and start bolting up hotside
install larger pump
wiring!
make room for intercooler
118,895
aquire rusty ass explorer rear
cut down
weld new perches on
slam home
get some wiring done, oil lines, junkyard E fans
junkyard 5 lugs and tires
attach brake lines
make some magic happen
torch em
currently wiring in traction control to test but she's wild!
118,895
500 @ 6 psi
608 on 10psi lifting because fuel running out, I have some kinks in the plastic feed line thinking that's it lol pretty happy it's making 28~whp per psi so might go 700 on 15ish crazy. No wonder it's a handful on 6 psi
118,895
so i cut a screwdriver head off, welded it to the inside of my 4wd front hub and welded a hurst shifter bracket eyelet to the hub assembly and pointed it at the screwdriver head, bam, instant VSS2, and working traction control, now to model it out and tune it for the vehicle.
yes, even i think this is rediculous but holy fuck it works
