Building a heavily modified Toyota Land Cruiser FZJ80
118,936
Figured some of you folks might enjoy this. I'll try and keep the thread updated as the owner does.
This is how the truck came in, shipped from OR, 1993 244k miles. Triple locked, completely stock aside from the ARB bumper. The truck needed a lot of maintenance as well, pretty much had all the standard leaks and things needing replacement. We also replaced a lot of things 'since we were there'. To be honest with you the customer will never push this truck anywhere near its limits but it's what he wanted and he had the cash.
When we started to tear it apart he decided to have the whole thing repainted, a new carpet, sound deadening, tons of electrical accessories, so that added a lot of extra work, the interior was completely stripped.
Compression numbers were acceptable on the engine so he decided to stick with it for now but will likely do a Cummins swap in the future, which is smart since we are adding about 2,000lbs of weight to this thing. Dual NorthStar batteries, Krieger 1500w inverter, Delta front and rear bumpers, 12,000lb Warn winch, Bowfin roof rack, four person RTT, Slee sliders, Long Range 35 gal fuel tank and 42 gal aux tank :rofl:
Basically everything on the engine was resealed except for the headgasket. Axles completely gone through, Icon shocks, Dobinsons, Wits End and Delta components make up the suspension. Most other parts were replaced with OE Toyota pieces.
Step one: Drain coolant.
All coolant hoses gone through
New steering and trans cooler lines
Off to the paint shop
Breaking down the front axle
3.5" Heavy springs
35" tars, wheels were powdercoated.
Switch Pro to control all the lighting and ARB compressor.
Replacement main fuel tank, 35 gal.
Aux tank, 42gal.
Got some refreshments from the customer :cool:
First time out of the shop in months
This upcoming week I'll post more pics as we get closer to the finish line.
118,936
More PICS
Main engine battery with a BlueSea power distribution block to run the winch off of (not wired in yet)
Aux battery which runs most of the other accessories (lights, compressor, switchpro, inverter and rear power hubs)
This little guy allows you to jump start the engine battery with the auxiliary battery if needed.
Compressor, yet to be mounted and plumbed
Gauge and switch for the transfer pump for the 42 gallon auxiliary tank, pressing the switch pumps fuel into the main tank.
Delta center console with all kinds of storage, flip away cup holders and glock holster :mamoru:
The leather needs to be dyed on the top.
Hella wires running from the SwitchPro
Power distribution block for the auxiliary battery
This is the SwitchPro brain
Delta SwitchPro mount, has a spot for two gauges as well but they'll be left blank for now, probably until it gets an engine swap that includes boost.
Two USB hubs that are powered all the time.
Illuminated, all of these eight switches can be used for various functions, we've got five used up for all the lights and compressor.
118,936
Slee sliders, excuse the dirt.
A shot of the rear suspension, Wits End extended lower control arms to help the pinion angle, and Wits End extended sway bar links.
Icon remote reservoirs tucked up, ten way adjustable. Borla exhaust, we also installed new factory downpipes and a cat delete since OBD1.
Another shot of the front, Delta caster correcting radius arms help keep things in line.
All new Toyota brake lines to every caliper, Icon stainless steel extended lines to the axles.
Shot of the engine bay
The rear ladder
Front and rear ditch lights, fog lights and bumper lights from Baja Design, ridiculous lighting on this thing, way overkill. Customer actually ordered a third amber light that we talked him out of installing since it would completely block the radiator air flow.
And we'll wrap things up with a shot of the front with the front bumper on for test fitting. Customer is flying in from ATL Friday to pick it up.
118,936
It's all done! Customer came in front Atlanta today and was super excited to take delivery. We are going to hit some trails tomorrow so I'll post some pics from that as well.
We had to custom make a panel to mount all the electrical accessories to, we were supposed to get one from an aftermarket company that fits everything behind the stock trim panel but it didn't show up in time, so this will work for now.
Moon Glow Metallic, looks pretty sick.
Reactions: Tk001
