I tried searching but only found a ton of for sale posts. It looks like TCG got out of aquariums, and I don't blame them! One big difference between fish and turtles though is that fish die. I'm so that means I've had the same two turtles for more than half my lifetime. I'm not giving up on them now!
I really need to get a second tank so that they each have their own permanent space, but I'd really like to dial in my existing tank first. It's a 75 gallon which is good enough for one turtle, but my filtration is lacking bad. I have one of those little deals that hang on the side of the tank which needs to be cleaned every few days. I'm looking to replace it with a Fluval FX6, which should at least allow me to get away with only partial water changes and monthly filter tear downs.
My questions are in regards to plumbing. My 75 gallon tank is not drilled although I do have some diamond hole saws. Worth it? Should I plumb it up the side with PVC and ball valves like I've seen in other set-ups? This tank is in my living room, so I want it to look as well as it needs to function. Part of my problem with running up the side of the tank is that I have no room in the back, and you're not supposed to have any horizontal sections of plumbing, so no bulkhead on the side. I don't see why it would matter much, but maybe somebody can set me straight?
