It certainly made fixing the wires MUCH easier. Strip some insulation, twist some wire, properly twist the two wires together and slide the sleeve over the exposed wires and center it. Then just hit it with a heat gun and bam. Instant weather resistant sealed electrically connection. I went and redid some of the other wires that were just old crimp connectors. Whether it helped or not, I don't know, but sure made me feel better.ED:Fack, indeed wrong thread.
Contributing something meaningful to this discussion at hand from what I've read and been told you should NOT actually be doing soldering in cars for wires. The solder wicks up the wire and causes it to work fracture over time. Not sure how true that is but I heard it on the Internet.
The crimp connectors with built in glue/shrink are fucking awesome. I think Denmah has even used those babies in gas tanks before from what I remember. I bet your wire will go to shit before they do.
Got the hopefully last of the wires spliced in. Just have to change the oil (not nessesary, but its been a while, so it needs a change), put the battery back into the car and key on to check for issues, then start the car time.
Ended up using a bunch of these. Honestly like them as far as ease of use if you don't have a garage where you can properly solder connections.
Never used these before, but remember seeing them before. But after having to do a bunch on the GTA to fix the damage, I really like these. If I can't get them on a solder bench to really get the solder into the joint these rock.
