Any 3800 tuners near Chicago area? 2000 buick
chicagochuck
I have a 2000 Buick regal and want to get a evap code deleted for small evap leak. Only getting 13 mpg , engine light on, I'm thinking that may be the culprit plus emission will be soon.
I found a guy a few years ago for my other Buick regal through this site ,but lost the info. Any help would be appreciated.
10sec
You could just get a programed PCM from the Wbodystore that has the code deleted. That's the easiest route. Unless someone with HPT can license your car really quick and just delete it for you.
PANDA
FRG
why not just fix the leak?
C
chicagochuck
iv been chasing this code, Kind of hard to diagnose, gas tank hose, gas filler neck, or some evap line ...
C
chicagochuck
I figured because the engine light was on it could be in some sort of default mode... But that's good to know. I did tune up a few months ago plugs/wires/oil/air filter, I check the tire pressure quite often . it runs really good just the mileage and the premium gas isn't cheap ...
I need to change the fuel filter.
how many miles are on the Upstream oxygen sensor? the one on the rear exhaust manifold near the number 4 and 6 spark plugs.
it is a primary trusted sensor and they are commonly skewed off of correct stoichiometric after 50000 miles or more
C
chicagochuck
Well Iv never changed it. It was supposedly changed by the previous owner The car has been in the family since 127,000 miles it has about 179,000 now. So at-least 50,000
