Hey guys,
I bought some -12 braided nylon hose and ends from Summit and the installation didn't go as easily as I expected. Perhaps I'm expecting too much, but I guess that's why I'm here.
I know there's a lot of black to be able to see what's going on, but these are the two piece design and they both have a lot of space between their mates. The one side of the hose end (I'll call it the nut) screws left handed onto the hose. Then the fitting side piece threads into the open end of the nut while simultaneously wedging the hose into the nut and locking it in place. My question is regarding whether or not the two pieces are supposed to get closer to bottoming out. The pic below shows that they should not bottom out, but that super tight spec does not give me confidence that I've done it right. Mine have about a 1/4" of clearance. I tried lubing everything up with WD-40 before putting them together, but it didn't help much. This is also using a wrench on one side and the bench vice on the other. Thanks in advance!
