ABS Light
Altiery54
Braidwood
Playing with the suspension last week and had to throw some lubricant on and some how it got inside of the abs sensor right next to the hub assembly and now my ABS light is on.... I tried to clean it off and such but to no avail.. Any suggestions on cleaning it or where the hell to get a replacement at?
Importsnrice
The tech kid!!
Hoffman Estates
Brakleen is your friend!! Also check to see if any wires got broken or any connections got messed around with etc.
Oreif
Crazy Little Child
Schaumburg
If it was a lube, It's probably really dirt. Try Brakkleen as recommended above.
If that doesn't work then you killed the sensor. You should be able to get a new one at an auto parts store or at a dealership.
Unless of course it's one of the ones that is IN the hub, in which case you need a new hub assembly.
Runtz52
Manhattan
ur brakes are probably scared to stop all that power u got under the hood, lol
