Sadly yea; it’s for the wipers only however is my understanding, which are inoperable anyways currently… may figure something else out there later…Does your pump have a vacuum pump on the top of it?
Okay so while I was bored I did some searching with certain terms and I've came across a bunch of stuff but the primary thing is that most people agree that unless you have a Golden Horseshoe shoved up your ass and you managed to find a complete electric wiper setup.....
....your kind of better off using an aftermarket high-quality electric vacuum pump and just overhauling the vacuum wiper actuator as most recommendations are.
Yea, it’s mounted a little ghetto right now just to make sure it would work; I can mount it down low in a cool area, but it’s VERY far forward, so I’m a little leery from “if it throws a belt or there’s an accident” perspective, so I’m still figuring that out. Also if I cut the front hard line back a bit it’s going to be in the way of the oil filter which is already a little tight.Remember those electric piston type pumps aren't as good at suction as they are with pressure so try to mount it down low and preferably away from the exhaust you would probably be fine to put it on the frame rail near where the mechanical pump was that's typically where we ended up doing those conversions and mounting them
How do the points look do you have a dwell meter?
The new petronix setups are pretty darn good
I have wired a manual switch interrupt into the cabin so I can at least do that manuallyAlso, you should really get an Airtex OS75 safety switch for that pump. You hook it into your oil pressure that way if the engine drops oil pressure it cuts fuel. That makes it so you don't have it keep pumping if a line breaks. It's a common OEM feature, you may have one or two leftover from parts cars. Reference image hijacked from another site, credit to them for it.
James doesn't think it's hurt, but basically I was initially hard-line of "If the engine has to come out I'd rather put something more modern in". The oil pump isn't servicible engine in due to it being unibody, so it had to come out.Fuck, you think she's wounded? I would guess so based on the WTB ad.
It's funny how little difference there looks to be between that engine, my 94 4.0L or my 82 258. Has to be an engine that was produced in immense numbers over decades in its various incarnations just like an SBC.
