460 Spread Sheet
TaeWade24
Chevy_Killa
Aug 30, 2016
19
A460 block
(572 BBF)
Bored 4.500"
Torque plate honed (represents head being torqued to block)
New Wide Performance cam bearings installed
New Brass freeze plugs installed
All New oil galley plugs installed
Painted color choice w/High Heat Paint
Rotating assembly
Scatt 4.500" stroke crankshaft
Scatt 4340 H-beam 6.700" rods
Clevite Hardened Rod & Main Bearings
JE Forged Pistons Dish pistons 10.5:1 compression
JE Performance File Fit Rings
All Rods big & small ends and Pistons machined to same weight
Rotating assembly balanced to race specs with printed spec sheet(.02 of oz. inch or within 2 grams
Kasse P51 Cylinder Heads
72cc CNC combustion chambers
310cc intake runners
Bronze valve guides
Hardened valve seats
2.250" and 1.760" Ferrea 6000 Race Series Stainless Steel valves
Comp Cams Roller valve springs
Comp Cams Titanium retainers
Comp Cams 10 degree hardened keepers
ARP Head Studs
Camshaft specs
Comp Cams Custom Solid Roller
Comp Cams Solid Roller Lifters
Comp Cams Torington Bearing Cam Retain Plate
ARP 7/16 Screw in studs
Kasse 7/16 Guide plates
Smith Brothers hardened pushrods
Crower 1.8 full roller race series rocker arms with poly locks
Billet True Double Roller timing set
Moroso 8qt street strip rear sump oil pan & pickup
Kasse Bullet Proof Casting, Dual Oil Feed oil pump
Milodon Hardned oil pump shaft
Fel-Pro Head Gaskets
Fel-Pro Timing Cover Gaskets & Rear Main Gasket
Fel-Pro Intake Gaskets
Fel-Pro Oil Pan Gasket
Ford Racing Aluminum Valve Covers
Fel Pro Valve Cover Gaskets
  • TaeWade24
  • 3
  • 447
