đź“° Auto News 2022 Kia EV6 GT Is a High-Performance EV with 577 HP and AWD
118,905
Kia has surprised us with a high-performance version of its new electric car, the EV6. Called the EV6 GT, this range-topping model features a all-wheel-drive powertrain with front and rear electric motors that produce a total of 577 horsepower and 546 pound-feet of torque. It's available only with the larger of the EV6's two battery packs and also features visual tweaks to set it apart from the lesser versions.
Kia's performance claims for the GT are impressive: a sprint to 62 mph in 3.5 seconds and a top speed of 128 mph. It also features software that is said to to mimic the behavior of a limited-slip differential. Hyundai has not announced any sort of performance version of the related Ioniq 5 EV, so Kia may have the exclusive on this high-powered drivetrain.
The GT looks a bit different than other EV6s thanks to larger wheels and tires and more aggressive front and rear fascias. Yellow brake calipers match with yellow accents found inside the cabin, and the seats look sporty and aggressively bolstered. There will also be a GT-Line version of the EV6 with similar visual changes as the GT but a smaller battery pack and less powerful drivetrains.
The various configurations for the standard EV6 and GT-Line models include a 168-hp one-motor RWD model or a 232-hp two-motor AWD model with the Standard Range battery pack and a 225-hp one-motor RWD and a 321-hp two-motor AWD model with the Long Range battery pack. Kia claims that the RWD Long Range configuration will provide a 316-mile range on the European WLTP cycle; U.S.-specific EPA range numbers will likely be lower.
We should get more detailed U.S. information for the EV6 within the next few months, as Kia says that its first EV will go on sale in the second half of this year. We expect a starting price of around $45,000 for the standard model, with the performance-oriented GT pushing much higher than that.
39,360
I thought they said 300 mile range estimated?
Correct. The battery capacity/power is going to be tiered so that each combination yields around 300 miles. I’m not sure how they’re going to do that with the 77.4 battery at three different performance levels though, adding in AWD:
The EV6 uses the E-GMP modular platform shared with Hyundai and will offer single- and dual-motor powertrains, as well as two battery options. The base EV6 will be a single-motor, rear-drive version with a 58.0-kilowatt-hour battery and 160-kilowatt motor providing up to 167 horsepower. Another rear-wheel-drive model will offer a 77.4-kWh battery and 160-kW motor providing 218 hp. Moving further up the lineup is an all-wheel-drive model with 77.4-kWh battery, with a 70-kW motor up front and 160-kW motor in the rear providing a total of 313 hp and 0–60 time of 5.1 seconds. The all-wheel-drive EV6 GT, coming in late 2022, features the same 77.4-kWh battery, with a 160-kW front motor and 270-kW rear motor providing 576 hp and the aforementioned 0–60 time of under 3.5 seconds.
118,905
bimmer4life
5,340
8,526
Wheaton, Illinois
