2022 Boat Craigslist & Ebay finds.
89,610
solid rig
PANDA
Event Coordinator
8,572
Wisconsin Northwoods
This is a deal if its legit. Its probably not tho. No registration numbers. low res pics. weird description. no phone number.
2016-Bennington 24' Tri Toon / Pontoon msw - boats - by owner -... (craigslist.org)
2016 Bennington 24 SLX3 w/ Yamhah 150 HP (Four Stroke / EFI) Outboard Engine - Garmin GPS In Dash Display Screen (Networked w/ Yamaha Engine / Monitoring System) - LED Ice Blue Bimini Top Lighting - In Floor Storage Compartment - Full Vinyl Bamboo Flooring
PANDA
Event Coordinator
8,572
13 1/2' row boat -battelship - boats - by owner - marine sale (craigslist.org)
HOME MADE BATTLESHIP . USED ROW BOAT , MADE OUT OF ALUMINUM & WOOD . A 30 LB THRUST ELECTRIC MOTOR , FOOT CONTROL ,CONVERTED TO HAND&ARM CONTROL . NO TRAILER . THE BACK LIGHT WORKS , NOT MOUNTED . THE RED CANONS LIGHT UP ON BOTH SIDES , WITH 8 SETTINGS . THE BOAT WAS TESTED , HAS SMALL LEAKS, FIXED MOST OF THEM . THE TEST LASTED OVER ONE HOUR ON THE WATER . THIS CRAFT IS TRICKY TO STEER . LOT OF FUN . NEED A NEW BATTERY . LOTS OF POSSIBILITY FOR LUNCHING FIRE WORKS. NO TITLE . TAG WAS REMOVED . CAN SEE OLD IL NUMBERS GHOSTED . ANY QUESTIONS EMAIL ME . THE BOAT CAME WITH 4 OAR HOLDERS MOUNTED.GOT THEM IN A BAG , IN THE BOAT. HOPE THE PICS TELL ALL . THE MOTOR WAS CUSTOM MOUNTED . UNCOVERED IT LAST SUMMER & FOUND THE PLYWOOD ON THE BACK OF THE BOAT , PEALING APART. THIS WILL MAKE A GREAT PROJECT . STORED IN FOX LAKE AREA.
Blood on Blood
rumble baby rumble
Apr 6, 2005
56,819
46,645
Now that is one battleship that will not survive a maiden voyage across any decent size lake
89,610
Reactions: SaturdaysGS
89,610
2001 28’ Dave’s Custom Boats, Teague 1000 engine, Imco SC drive, Imco Extension box, Imco full hydraulic steering, Dana long trim tabs, Gaffrig Gauges, 600 watt Alpine Stereo system, 10” subs, pre-lube system, heavy duty oil cooler, dual sea strainers, triple axle trailer with 4 wheel disc brakes, very clean and reliable. Ready for the water.
Reactions: Jon01
89,610
would.
not great for the chain but doable. but would be at home well enough on the big pond i feel.
Reactions: Jon01
Blood on Blood
rumble baby rumble
Apr 6, 2005
56,819
46,645
would.
Clean. Drive it down the St Joe’s or New Buffalo
Reactions: Jon01 and Yaj Yak
