2021 TCG Thursdays | Algonquin | 7:00pm
32,650
16,131
Exhaust fixed, vss nearly done.
I had to hit all my harnesses to find the early 90's connector :rofl:
Driveshaft appears tight.....as tight as 4 m8x1.25 bolts can be.
Tiny coolant leak at my water pump lower radiator hose....
coolant overflow is now finished and no longer spitting coolant onto my exhaust.
I'll be driving it to my work tomorrow morning and I'll let you guys know if I feel like it will make it up there...
I need to water jet a slightly different version of my exhaust hanger but it's good enough that I'm going to leave it for now.
Cross your fingers for me
Gav'sPurpleZ
39,127
14,982
Pingree Grove IL
32,650
16,131
I added six zipties to the hood latch "support".
I'm at the Berrington IHOP pissing off everyone behind me on 90
410 rear gears are quite fun.... until you get on the highway
Nailed it under 290 while I was getting on to 90.
quite enjoyable under the bridge
It's a 3800 I have to leave early to get there on time
