2001 GTP Coupe
Xtant12
Well the time has came. After all the time and money spent it's time to move on. I'm officially selling my GTP. Figured I would post on here first. It has the L26 top swop. GenV blower, zzp heads, full size intercooler, zzp race trans. Pace setter headers, 80 lbs injectors, E85 fuel pump, currently running on pump gas. Last Dyno on pump gas was 309. When was on E85 was 360.
Asking 3,000
Xtant12
This app will absolutely not allow me to add pictures
10sec
Just upload them to imgur and bring them over here. Super easy. But it's also super easy to put them in using the app :rofl:
Xtant12
What error does it give you
It doesn't see them, so I hit the option tab in top right corner, change it to use system configuration, the select the file and picture. When it loads it says load failed
tinfoilhat
Riding the Hubble
hm. i have issues if it is a .png file. i have to convert it to .jpg for it to attach
Mr. SBF
Keeping it Real with Ford Power!!!
Kenosha County
I don't use the app. I resize a template picture close to the max size allowed and then just edit/add new picture I want to post over that template each time. Many way's to skin a cat...
PANDA
FRG
360whp on E85 with a stock cam? :rofl:
10sec
It has an XPZ cam. You cannot read.
boostedguy05
not well known
Asking 3,000
in Panda's defence, he mentions nothing of the cam in the post.
Xtant12
WHAT 10SEC SAID.
It has the XPZ CAM
GOD DAM PANDA
The car has a LOT of stuff. I was short on time and couldnt list everything. I figured people would PM me if they had any questions. I was right, I have received 4.
b4black
Oswego
Where is at?
You have a ZZP tune and a powertuner. Does this let you see what ZZP changes for their canned tunes?
b4black
Oswego
OK, my mistake. I figured a "ZZP 2.0 Tune" was canned.
Doesn't matter - same question. Can you view what they did with the powertuner?
Also, what do they do when swapping from gasoline to E85? Pull timing or pulley up?
1quick
coal city
On e85 they add fuel and timing and normally pulley down, your better off adding boost over timing in my experience
Xtant12
Yes you can scan and tune it with the powertuner. For E85 they drained it and re-tuned for 93 pump gas. They left the E85 fuel pump in because it was high flow and still would work with gas.
b4black
Oswego
I know what a powertuner is and does. I was just wondering if you looked at what they did. Not that they 'retuned' it, but what exactly they did. I guessing you wanted to go back and forth between gasoline and E85. Besides swapping fuel, you adjust the injector skew and then pull/add X° or pulley up/down X" or both.
I know what can be done (and I know what I do), just wondering what the "professionals" do.
Xtant12
This app will not load any pictures in my gallery.........
Bru
I can see them.
Xtant12
I had to email them from my phone to my email, then save them to my work computer. Then upload them to Photobucket and put into post.
10sec
Them rockers seenT better days, innit?
