04 GTP traction and stability issues
Royalgtp
My traction and stability control lights go on and off all the time for no apparent reason. Ive checed the ABS wires and they are all fine. Any clues?
very possible it's a wheel speed sensor dropping out, but that will also trigger abs, does the abs light come on as well?
Royalgtp
No abs light at all. it use to just be traction control that came on for like the last year and now its stability too.
SaturdaysGS
Chicago (Southside)
I think someone had a similar issue on ClubGP and it turned out to be something with the BCM. IIRC. Unfortunately I cant help as I havent had this problem, yet. Everything else I have though.
TonzKnock-G
Shitcago
i wouldnt worry about it. shit used to happen to me every so often so i would just turn the car off and on and it would go away, if it didnt on its own. When you say all the time do you actually mean all the time? If so then something might be up.
Royalgtp
Yes, its very on and off issue. Sometimes its on, sometimes its off for no reason whatsoever.
