Guys Im looking for the blue turning signal balbs that you use to be able to get al wallmart. I cant seem to find them anywhere. They were the ones that the glass has a blue tint in it.. Does anyone know where to get these at??
You're looking for APC super whites...
3157...
I use them in my tails and anywhere that an AMBER bulb is not required...
and as 10secsomeday is saying in his post, we are not responsible for any tickets you may receive while using these bulbs...
just get some Silverstar Euro Amber 3157s for your front turn signals and never have to worry...
I am pretty sure that amber is the only legal color in IL for turn signal bulbs, etc. when it comes to passenger vehicles.
(625 ILCS 5/12-208) (from Ch. 95 1/2, par. 12-208)
Sec. 12-208. Signal lamps and signal devices.
(a) Every vehicle other than an antique vehicle displaying an antique
plate operated in this State shall be equipped with a stop lamp or lamps on
the rear of the vehicle which shall display a red or amber light visible from
a distance of not less than 500 feet to the rear in normal sunlight and which
shall be actuated upon application of the service (foot) brake, and which may
but need not be incorporated with other rear lamps. During times when lighted
lamps are not required, an antique vehicle may be equipped with a stop lamp
or lamps on the rear of such vehicle of the same type originally installed by
the manufacturer as original equipment and in working order. However, at all
other times, except as provided in subsection (a-1), such antique vehicle
must be equipped with stop lamps meeting the requirements of Section 12-208
of this Act.
(a-1) An antique vehicle, including an antique motorcycle, may display a
blue light or lights of up to one inch in diameter as part of the vehicle's
rear stop lamp or lamps.
(b) Every motor vehicle other than an antique vehicle displaying an
antique plate shall be equipped with an electric turn signal device which
shall indicate the intention of the driver to turn to the right or to the
left in the form of flashing lights located at and showing to the front and
rear of the vehicle on the side of the vehicle toward which the turn is to be
made. The lamps showing to the front shall be mounted on the same level and
as widely spaced laterally as practicable and, when signaling, shall emit a
white or amber light, or any shade of light between white and amber. The
lamps showing to the rear shall be mounted on the same level and as widely
spaced laterally as practicable and, when signaling, shall emit a red or
amber light. An antique vehicle shall be equipped with a turn signal device
of the same type originally installed by the manufacturer as original
(c) Every trailer and semitrailer shall be equipped with an electric turn
signal device which indicates the intention of the driver in the power unit
to turn to the right or to the left in the form of flashing red or amber
lights located at the rear of the vehicle on the side toward which the turn
is to be made and mounted on the same level and as widely spaced laterally as
practicable.
(d) Turn signal lamps must be visible from a distance of not less than
300 feet in normal sunlight.
(e) Motorcycles and motor-driven cycles need not be equipped with
electric turn signals. Antique vehicles need not be equipped with turn
signals unless such were installed by the manufacturer as original equipment.
(f) For purposes of this Section, a custom vehicle or street rod is
considered to be in compliance with all signal lamp and signal device
requirements if it has passed the approved safety inspection provided for in
Section 3-804.1 or 3-804.2.
(Source: P.A. 94-299, eff. 7-21-05.)
Ive never had any issues for "blue" turn signal bulbs and theyve been that color for years
Move this thread to imports
:slap: :gtfo2:
