Anyone need some nostalgia for their next bike?
The Halcyon 450cc Motorcycle is lightweight, classic, and hand-built. Customize and build your dream motorcycle today!
www.janusmotorcycles.com
ENGINE
Type: Air/oil-cooled, 4-stroke, single cylinder
Displacement: 445cc
Compression ratio: 10:1
Starting: Electric
TIMING SYSTEM
Type: Single overhead camshaft, 4 valve
LUBRICATION
Type: Dry sump with gerotor pump, cartridge filter, and oil cooler
IGNITION
Type: Electronic
FUEL SYSTEM
Type: Electronic fuel injection
PRIMARY DRIVE
Drive pinion gear: 24
Clutch ring gear: 64
Transmission ratio: 2.667
CLUTCH
Type: Wet, multi-plate
CHASSIS
Type: Frame: DOM tubular steel double cradle
FRONT SUSPENSION
Type: Proprietary leading-link fork with dual progressive coil-over Ikon shocks
REAR SUSPENSION
Type: Proprietary cantilever transom with dual progressive coil-over Ikon shocks
FRONT BRAKE
Type: 280mm disc with two-piston Brembo floating caliper
REAR BRAKE
Type: 220mm disc with single-piston Brembo floating caliper
RUNNING GEAR, & DISPLAYS
Wheels: CNC machined aluminum hubs with aluminum alloy rims and stainless steel straight-pull spokes
Tires: Front 4.00 x 18, Back 4.50 x 18
Instrumentation: Digital tachometer, speedometer and odometer, with LCD screen and indicator lights
PERFORMANCE, DIMENSIONS, & CAPACITIES
Maximum Power: 30 hp @ 7,500 rpm
Maximum Speed: 90mph
Dimensions: 86’’ long & 31’’ wide. Height without mirrors: 41 inches
Seat Height: 30”
Wheelbase: 56 inches
Fuel Capacity: 2 gal
Dry Weight: 345 pounds
