What to do v. Garage heaters
keitho64
152
SW Burbs
I've had my Profusion heater installed for about 6 years ago. I did electric due to install cost issues and venting for gas.
My garage is 26'x28' with 10' ceilings. It is completely insulated, 2" insulated door and two interior walls. In the coldest of months the electric bill is 35-40 more with it running full time at 65 degrees. That has been the worst case. Most of the time I keep it around 60 and the bills are 25-30 more per month.
It makes working on the cars so much better in winter.
107,640
Which Profusion do you have and do you run a separate T Stat for it? I'm going to get rid of my Propane and go electric once we run new service out to my garage in the next month.
keitho64
152
SW Burbs
I have the Profusion EH-4604. It has three BTU settings and a built in fan.
I did not wire in a thermostat. The unit has a temp dial which I learned where to keep it and maintain the temp in the garage.
It was the best $100 investment I made in the garage. Now if I could get a lift.... [emoji2]
MrMezger996
Formerly CobraSki
3,046
3,369
Hoffman Estates
Finally got around to finishing my garage heater install just in time for spring!! Also ran a 100amp sub panel to garage. I’ll be able to run welder on 220 now and my quick jack lift will not keep popping breaker.
