Torque Spec for 97' - 03' Grand Prix
119,007
TORQUE SPECS FOR 1997 - 2003 Grand Prix (Other W Bodies should be similar)
Accelerator Control Cable Bracket Bolt 16 Nm (12 ft. lbs.)
Balance Shaft Driven Gear Bolt 22 + 70?Nm (16 + 70?ft. lbs.)
Balance Shaft Retainer Bolt 30 Nm (22 ft. lbs.)
Camshaft Position Sensor Bolt 10 Nm (89 inch lbs.)
Camshaft Sprocket Bolt 100 + 90?Nm (74 + 90?ft. lbs.)
Camshaft Thrust Plate Bolt 15 Nm (11 ft. lbs.)
Canister Purge Solenoid Valve Bracket Bolt (VIN K) 50 Nm (37 ft. lbs.)
Canister Purge Vacuum Switch Bolt (VIN K) 50 Nm (37 ft. lbs.)
Connecting Rod Cap Bolt 27 + 50?Nm (20 + 50?ft. lbs.)
Crankshaft Balancer Bolt 150 + 76?Nm (111 + 76?ft. lbs.)
Crankshaft Main Bearing Cap Bolt 40 + 110?Nm (30 + 110?ft. lbs.)
Crankshaft Main Bearing Cap Bolt (Side) 15 + 45?Nm (11 + 45?ft. lbs.)
Crankshaft Position Sensor Stud 30 Nm (22 ft. lbs.)
Crankshaft Rear Oil Seal Housing Bolt 15 + 50?Nm + (11 + 50?ft. lbs.)
Cylinder Head Bolt 50 + 120?Nm (37 + 120?ft. lbs.)
Drive Belt Tensioner Bracket Bolt/Nut 50 Nm (37 ft. lbs.)
Drive Belt Tensioner Bracket Stud 6 Nm (53 inch lbs.)
EGR Valve Adapter Bolt 50 Nm (37 ft. lbs.)
EGR Valve Inlet Pipe Bolt 29 Nm (21 ft. lbs.)
EGR Valve Nut 29 Nm (21 ft. lbs.)
EGR Valve Outlet Pipe Bolt/Nut 29 Nm (21 ft. lbs.)
Engine Block Coolant Drain Plug (VIN 1) 18 Nm (13 ft. lbs.)
Engine Block Coolant Drain Plug (VIN K) 30 Nm (22 ft. lbs.)
Engine Block Oil Gallery Plug 30 Nm (22 ft. lbs.)
Engine Coolant Temperature Sensor 25 Nm (18 ft. lbs.)
Engine Flywheel Bolt 15 + 50?Nm (11 + 50?ft. lbs.)
Engine Front Cover Bolt/Stud 20 + 40?Nm (15 + 40?ft. lbs.)
Engine Lift Bracket Bolt/Nut/Stud 30 Nm (22 ft. lbs.)
Engine Mount Nut, Lower 78 Nm (58 ft. lbs.)
Engine Mount Nut, Upper 78 Nm (58 ft. lbs.)
Engine Oil Pressure Indicator Switch 16 Nm (12 ft. lbs.)
Exhaust Crossover Heat Shield Nut 20 Nm (15 ft. lbs.)
Exhaust Crossover Pipe Bolt/Stud 20 Nm (15 ft. lbs.)
Exhaust Manifold Bolt/Nut 30 Nm (22 ft. lbs.)
Exhaust Manifold Heat Shield Nut 20 Nm (15 ft. lbs.)
Exhaust Manifold Stud (Inner) 30 Nm (22 ft. lbs.)
Exhaust Manifold Stud (Outer) 10 Nm (89 inch lbs.)
Fuel Injector Rail Nut 10 Nm (89 inch lbs.)
Fuel Injector Rail Stud 25 Nm (18 ft. lbs.)
Fuel Injector Sight Shield Bracket Nut 30 Nm (22 ft. lbs.)
Generator Brace Bracket Bolt 50 Nm (37 ft. lbs.)
Heated Oxygen Sensor 42 Nm (31 ft. lbs.)
ICM Bolt (VIN 1) 30 Nm (22 ft. lbs.)
ICM Nut 50 Nm (37 ft. lbs.)
ICM Stud (VIN K) 6 Nm (53 inch lbs.)
ICM Wiring Harness Bolt 2 Nm (18 inch lbs.)
Idler Pulley Bolt 50 Nm (37 ft. lbs.)
Idler Pulley Bracket Bolt 30 Nm (22 ft. lbs.)
Lower Intake Manifold Bolt 15 Nm (11 ft. lbs.)
MAP Sensor Bolt (VIN 1) 3 Nm (27 inch lbs.)
MAP Sensor Bracket Bolt (VIN 1) 30 Nm (22 ft. lbs.)
Oil Cooler Adapter Connector 50 Nm (37 ft. lbs.)
Oil Filter 30 Nm (22 ft. lbs.)
Oil Filter Adapter Bolt 15 + 50?Nm (11 + 50?ft. lbs.)
Oil Level Indicator Switch 20 Nm (15 ft. lbs.)
Oil Level Indicator Tube Nut 19 Nm (14 ft. lbs.)
Oil Pan Bolt 14 Nm (125 inch lbs.)
Oil Pan Drain Plug 30 Nm (22 ft. lbs.)
Oil Pump Cover Screw 11 Nm (98 inch lbs.)
Oil Pump Screen Bolt 15 Nm (11 ft. lbs.)
Power Brake Booster Heat Shield Nut 20 Nm (15 ft. lbs.)
Spark Plug 27 Nm (20 ft. lbs.)
Starter Motor Heat Shield Bolt 30 Nm (22 ft. lbs.)
Supercharger Bolt/Stud (VIN 1) 23 Nm (17 ft. lbs.)
Supercharger Bypass Valve and Fuel Pressure Regulator Valve Harness Bolt (VIN 1) 10 Nm (89 inch lbs.)
Supercharger Bypass Valve Nut (VIN 1) 8 Nm (71 inch lbs.)
Throttle Body Nut 10 Nm (89 inch lbs.)
Throttle Body Support Bolt (VIN K) 10 Nm (89 inch lbs.)
Timing Chain Dampener Bolt 22 Nm (16 ft. lbs.)
Upper Intake Manifold Bolt (VIN K) 10 Nm (89 inch lbs.)
Valve Lifter Guide Retainer Bolt 30 Nm (22 ft. lbs.)
Valve Rocker Arm Bolt 15 + 90?Nm (11 + 90?ft. lbs.)
Valve Rocker Arm Cover Bolt 10 Nm (89 inch lbs.)
Water Outlet Bolt 27 Nm (20 ft. lbs.)
Water Pump Bolt 15 + 80?Nm (11 + 80?ft. lbs.)
Water Pump Pulley Bolt 13 Nm (116 inch lbs.)
Wiring Harness Shield Bolt/Nut 10 Nm (89 inch lbs.)
FRONT BRAKES:
Bleeder Valve
13 N?m 115 lb in
Brake Hose Bolt
54 N?m 40 lb ft
Caliper Bolts
85 N?m 63 lb ft
Caliper Bracket Bolts
185 N?m 137 lb ft
REAR BRAKES:
Bleeder Valve
11 N?m 97 lb in
Brake Hose Bolt
44 N?m 32 lb ft
Caliper Bolts
43 N?m 32 lb ft
125 N?m 92 lb ft
Rotor/J 37160-A Nut
34 N?m 25 lb ft
SUSPENSION - FRONT:
*Tighten the nut in order to align the cotter pin hole with the front lower
control arm ball stud. Do NOT loosen the nut in order to align the cotter pin
hole.
* Front Lower Control Arm Ball Stud to Steering Knuckle Nut
20 N?m+120? 15 lb ft+120?
Front Lower Control Ball Stud Nuts to Control Arm
68 N?m 50 lb ft
Front Lower Control Arm Mounting Nuts
104 N?m 77 lb ft
Front Stabilizer Shaft Bracket Bolt
48 N?m 35 lb ft
Front Stabilizer Shaft Link Nut
23 N?m 17 lb ft
Front Suspension Strut to Body Mount Nuts
33 N?m 24 lb ft
Front Suspension Strut Mount Nut
70 N?m 52 lb ft
Front Suspension Strut to Steering Knuckle Bolts
122 N?m 90 lb ft
Front Wheel Drive Shaft Bearing Nut
130 N?m 96 lb ft
SUSPENSION - REAR:
Rear Suspension Strut Shaft Nut
75 N?m 55 lb ft
Rear Suspension Support Mounting Bolt
110 N?m 81 lb ft
Rear Wheel Hub to Knuckle Bolts
75 N?m 55 lb ft
Rear Spindle Rods to Knuckle Nut
150 N?m 110 lb ft
Rear Wheel Spindle Rods to Rear Suspension Support Nut
140 N?m 103 lb ft
Stabilizer Shaft Insulator Bracket Bolts
48 N?m 35 lb ft
Stabilizer Shaft Link Nuts
35 N?m 26 lb ft
Strut Mount to Body Nuts
45 N?m 33 lb ft
Strut to Knuckle Nuts
122 N?m 90 lb ft
Trailing Arm Bracket to Body Nut
54 N?m 40 lb ft
Trailing Arm to Knuckle Bolt
70 N?m+65? 52 lb ft+65?
http://www.wbodystore.com/grandprix....html?osCsid=119c7b57a0983dfe91f486146c07f483
32,652
16,139
Rip wbodystore, alas poor M Mike K i knew him whell, someday those sweet beltwraps will do more than just look dusty.
Also I realize we really need to redo the torque table it may be pretty confusing for some people the way it's laid out value wise.
For those of you who are bolting on mods I generally go to 28 to 29 foot pounds with comp or ARP rocker bolts.
Head studs get four dugga-duggas and the middle 4 an additional dugga.
Hth
Reactions: GTPpower
  • Mook
  • 1
  • 4K
