The new 2018 Wrangler got awesome- better in every way.
Lord Tin Foilhat
60,730
56,898
Privy Chamber
Alternator doesnt send power to the engine to POWER the wheels....
neither does what they described....
Another name for a mild hybrid system; eTorque replaces the alternator with a Motor Generator Unit that charges the 12-volt battery CHARGES BATTERY, sends torque to the engine’s crankshaft via the accessory belt SENDS TORQUE TO CAMSHAFT, NOT WHEELS[/B], and turns the vehicle’s forward motion into current for the liquid-cooled 48-volt lithium-ion battery CONVERTS FORWARD MOTION FOR CHARGING BATTERY.
Just because it sends power to the crankshaft, doesn't mean its the only device doing it.
89,633
doesn't GM have a similar high voltage alternator for their "hybrid"cars?
this new wrangler looks awesome. finally an interior that isnt from the early 2000s. i hear it doesn't ride like a dump truck either. plus a doozel and hybrid? fuck yes jeep, well done
https://en.wikipedia.org/wiki/BAS_Hybrid
apparently for more than ten years :rofl:
BAS is an acronym for belted alternator starter. It is a category of automotive parallel hybrid technology that uses an electric motor to contribute power to the internal combustion engine's crankshaft via a serpentine belt. By mounting this motor generator unit in the conventional location traditionally used for the standard automotive alternator, it permits a low-cost method of adding mild hybrid capabilities such as start-stop, power assist, and mild levels of regenerative braking. BAS differ from other mild hybrid systems as they are not run off the vehicle's crankshaft.
General Motors introduced a mild hybrid system called belt alternator starter (or BAS) in the 2007 Saturn Vue Green Line. The BAS system is also used in the 2008-2009 Chevrolet Malibu Hybrid. It operates similarly to other mild hybrids with a start-stop system, in that it shuts down the engine as the vehicle comes to a stop and instantly restarts it when the brake pedal is released.[1]
RICH17
Dr. Pussy Slayer, MD
26,707
1,992
The 007
Adam Rich
but doesn't the engine send a metric BUTTFUCK ton of power through the belt to the alternator :rofl:
power from the battery
moves the generator
spins the belt
drives the crank
turns the gears
makes the tires go turny turny
okay so you dont think that would make for harder belt wear? Maybe they have an upgraded belt. Looks wide in the picture too
89,633
dude do you know what belts can power that take crazy amounts of power to turn?
89,633
But it comes with 33’s
The engineering team even designed all of the systems to protect for 35-inch tires, and the Rubicon now comes with one-inch-larger 33-inch tires standard.
I misunderstood that portion in my quick glance, my bad.
pretty awesome though that they are like HEY 35'S FIT AND ARE GOOD TO GO :rofl:
89,633
The Rubicon version of the JL has what amounts to a Mopar High Top fender kit from the factory, sitting a full 2 inches higher than the Sport or Sahara models. This allows the JL to fit 35-inch tires right from the showroom floor. You’ll want to add a 2-inch lift kit if you want full articulation without any rubbing on a Rubicon when running stock wheels..
almost
