The Chicago Garage Top Ten Lap Times - Road Courses
chris101
1,516
4
Mt. Prospect, IL
yes
Username of car owner: chris101
Driver Name: Chris
Car Driven: 95 Infiniti G20 prepped for NASA PTF (131whp, 2800lbs)
Gingerman Long Course, AMB Transponder 1:54.658 (Maxxis RC-1 )
Autobahn South Course, AMB Transponder 1:44.848 (Hoosier R6 Tires)
Autobahn Full Course AMB Transponder 3:01.534 (ancient used Hoosier R3S04 tires)
I have others with Traqmate but I have to look it up 1st.
chris101
1,516
4
Mt. Prospect, IL
yes
Please Update my Gingerman Time to say (LONG COURSE)
Here are some I have historically in other cars for Chris (Chris101):
Blackhawk:
1:22.681 HL 1990 Mustang - Avon Tech RA tires - traqmate
1:22.90 HL 96 993 Porsche 911 - Bridgestone S03 - Longacre HotLap Lap timer
1:26.881 HL 1990 Spec Miata - Toyo RA1 - AMB Transponder
1:26.458 HL 1995 Infiniti G20 - Hoosier R6 - AMB Transponder
Grattan:
1:30.46 HL 96 993 Porsche 911 - Bridgestone S03 - Longacre HotLap Lap timer
1:33.929 HL 95 Infiniti G20 - Hoosier R6 - AMB Transponder
1:34.71 HL '04 SRT-4 - Hankook RS3 - Longacre Hotlap Lap timer
10. 1:35.143 HL 1990 Mustang - Avon Tech RA - Traqmate
11. 1:35.823 HL 1990 Spec Miata - Toyo RA1 - AMB Transponder
Road America:
2:44.64 HL 96 993 Porsche 911 : Bridgestone S03 - Longacre HotLap Lap Timer
2:55.454 HL 95 Infiniti G20 - Hoosier R6 - Traqmate
2:57.000 HL 1990 Spec Miata - Toyo RA1 - Traqmate
Autobahn North:
1:19.82 HL '04 SRT-4 : Hankook RS3 - Longacre HotLap Lap Timer
1:20.472 HL 95 Infiniti G20 PTF - Hoosier R6 - AMB Transponder
1:17.914 HL 1990 Spec Miata - Toyo RA1 - Traqmate
1:16.14 HL 96 993 Porsche 911 - Bridgestone S03 - Longacre HotLap Timer
Autobahn South:
1:43.673 HL 1990 Spec Miata - Toyo RA1 - AMB Transponder
1:43.66 HL 96 993 Porsche 911 - Bridgestone S03 - Longacre HotLap Timer
..and I have updates for on Autobahn Full:
2:57.782 HL 95 Infiniti G20 - Hoosier R6 - Traqmate
2:57.816 HL 1990 Spec Miata - Toyo RA1 - Traqmate
3:03.14 HL '04 SRT-4 - Hankook RS3 - Longacre HotlLap Timer
2:54.81 HL 96 993 Porsche 911 - Bridgestone RS3 - Longacre HotLap Timer
Putnam:
1:28.652 HL 1990 Spec Miata - Toyo RA1 - AMB Transponder
1:28.967 HL 95 Infiniti G20 - Hoosier R6 - AMB Transponder
Gateway:
1:17.849 HL 1990 Spec Miata - Toyo RA1 - AMB Transponder
Brainerd - 2.5 Mile course
2:01.598 HL1990 Spec Miata - Toyo RA1 - AMB Transponder
Mid America MAM
1.57.011 HL 1995 Infiniti G20 - Hoosier R6 - AMB Transponder
2:06.100 HL 2012 Ford Fusion - Stock All Season tires (automatic rental car) - AMB Transponder
J-LO
3,093
1,719
In Da Hood
Blackhawk:
Grattan:
Road America:
Autobahn North:
Autobahn South:
Putnam:
Gateway:
Mid America MAM
Updated your ginger man, if you want me to use info from above, remove all but your fastest laps so i don't have to surf through it please.
Thanks
Thirdgen89GTA
19,408
16,034
Rockford
Bill
Do they make you safety wire any bolts and such ? Thanks for the reply .
Which car? Your ST?
See if you can get ahold of a tech form to self tech before showing up. Should show you what they require.
For an HPDE, I don't think its going to be much more than a car in good running order with no leaks, fresh brakes, fresh fluids, good tires, a helmet, and no loose nut behind the wheel. :)
Eagle
Nemo me impune lacessit
63,909
4,744
Woodsticks, IL
Can't wait to go back and beat my time once I got a patch!
Thirdgen89GTA
19,408
16,034
Rockford
Bill
No cage yet . I've been holding off on welding anything to the car because was not sure what direction I was going with the project.
Most HPDE will check the following.
  • Fluids must be fresh
  • Brakes must be in good shape, no cracking or warping. Cheap slotted/drilled are kind of no-no as they are more likely to fail when pushed.
  • Tires shouldn't be worn beyond wear indicators.
  • No leaks or loose/hanging items under the car.
  • Centercaps should be removed unless they can only come out if pushed from behind. Aka, anything that covers the lugs needs to come off.
  • Helmet should be current.
  • Seat belts should be in good repair, no tears, retractors should be working correctly.
  • Remove all loose items in the car, floor mats and the like.
  • Battery should be secured and positve cable is covered.
  • Brake lights must be functioning.
I'm sure there is more, but the general rule is your car should be in good running order.
sickmint79
I Drink Your Milkshake
Mar 2, 2008
27,079
16,897
grayslake
Do you have a cage? That can change the safety requirements for harnesses and such. Best to call them up and ask. If you can get a tech form, that should show you almost everything you need.
i'm not sure of all the ones in this area, except one i do know for sure is driver and instructor have to be matching if you're in a class that requires one. so you can't have something like a race seat and harness while the instructor has a regular seat and belt.
chris101
1,516
4
Mt. Prospect, IL
yes
Thanks
so if I'm understanding correctly, you only want 1 time per track per person regardless of car used, right?
If yes, here you go:
Blackhawk:
Grattan:
Road America:
Autobahn North:
Autobahn South:
Putnam:
Gateway:
Mid America MAM
Dan00Hawk
3,819
7,919
Plainfield
Username of car owner: Dan00Hawk
Driver Name: Dan Hoekstra
Track: Autobahn South
Configuration:
Car Driven: 1996 Firebird 3800 5 speed. 2900#
Tires: 275/40/17 Nitto NT05
Lap Time: 1:49.633 (1:45.892 best lap by co-driver Keith Prociuk)
Method of data acquisition: Lemons Race Timing
3:01.650 at Road America with a chicane after the carousel/before the kink during 2013 Lemons Race
