Slolane's Camaro Build for 2017 - Its Turbo Time!
Lead Pipe
TCG Sub-par Member
17,743
13,272
Does this count?
Tansky-Turbo-kits-Mini-Electric-Turbo-Supercharger-Kit-Air-font-b-Filter-b-font-Intake-for.jpg
Slolane
Who's The Masta!?!
Mar 27, 2009
7,493
4
Hoffman Estates
Looks nice. Is there a particular paint that is reccomended to use to paint the cylinder heads?
I just used the high heat engine enamel on the mock up motor to see how it turned out. Turned out fairly nice for only spraying down the motor with brake clean prior to spraying it lol. I'll likely use the same stuff for the new motor unless I find something more recommended. I'll let you know
Slolane
Who's The Masta!?!
Mar 27, 2009
7,493
4
Hoffman Estates
TCG Sponsored - Turbo Camaro (Fefe) Build
The final piece to the puzzle has arrived. Giggity
Trans and drive shaft are back in
Fuel system is done.
Now to paint the heads. Have new cam speced out.
Dress up the engine, and throw her on in. If all goes well. Should have oil pressure in no time. Crossing fingers.
Made the engine bay a little prettier too. Only fire wall for the time being.
Slolane
Who's The Masta!?!
Mar 27, 2009
7,493
4
Hoffman Estates
Houston we have a power plant. Wasn't easy but luckily I was @BlessedByDycus [MENTION=340]Eagle[/MENTION] to help throw the heavy pig in. Oh and [MENTION=5]Mook[/MENTION] with the excellent guidance skills. Once the cam comes back can throw the lifters in and heads on and it should be all smooth sailing from there. Let's hope...
118,948
You dont allow us play time with the dogs AND justin is the one drinking your beer. Do you forget I was the one to guide the driveshaft in AND I was the one continually remind you the motor was hitting the driverside motor mount? HMMMM?
Slolane
Who's The Masta!?!
Mar 27, 2009
7,493
4
Hoffman Estates
All I heard was. "Is it suppose to be hitting that" while I was breaking my fingers trying to man handle a iron block with just my finger tips.
