I've never seen this car drive-able in the years I've known you Peej. I'll probably shit my pants the moment I see it rolling down the block.
Can you elaborate on the 8.8 swap? Mustang or explorer rear? Back spacing? Driveshaft....etc?
I have a 68 also.
Good thing I don't see you anymore, will save you the embarrassment of poo running down your leg
No problem, it's a 94-98 mustang rear with cobra disc brakes. (Same as Fox housing, disc brake axles just push the wheels out another 3/4" or so). I cut off all the suspension tabs and had leaf spring perches welded on at the correct pinion angle. Was a pretty simple swap.
I don't remember driveshaft length but I think it remained the same as the 8". Currently running oem 99-04 Bullitt 17x8 wheels. I'd like to try and put a 17x9 under there but that's a problem for later
You're dismantling like 19 cars at once. Not my fault.
EAD PrattfordI corrected that for you.
Thanks. I have a couple more if your up for it?
When you went disc brakes in the rear, what master cylinder did you use? (im drum-drum manual currently)
Were you able to use the matching front wheels? Did you have back spacing issues?
Thanks.
Did it go bloop when you got her in?
Jesus Christ this thing is gonna be done before my turd, imma kill Dhruva [MENTION=8243]01bluesnake[/MENTION]
