Tore apart the motor tonight for a few reasons:
1. Want to verify the compression ratio. Cam builder needs it to do his best job
B. Motor was assembled by AES a few years ago and never ran. Their reputation can be sketchy. I want to double check the assembly and have some confidence in it
iii. I found a billet crank for sale in the exact size I need. I am measuring the bob weight of my setup (internally balanced) to see if it's relatively close. If I don't need to spend $800 on mallory heavy metal balancing it, then I will pick it up and sell my forged crank
Dry decked heads. All the coolant ports were welded and decked flat. If I lift a head, I'm not gonna spray coolant or pressurize the coolant system and get water under the tires. Great mod for a filled block
Pulled one piston and rod out. I am bringing it to the machine shop tomorrow to get it weighed. Fancy coatings and gas ports (not sure if they actually help, everyone argues about it)
