this dude is a gomer and i found his videos helpful when picking out new tech for my lappy
good vid
Linus isn't bad as far as content is concerned. However, his voice can be one of those voices that just grates on your ears. But he does do some cool builds.
Just get a 1070. Those are boss for everything including 1440p @144hz.
I don't know.. I have two 1080's in SLI and running Watch Dogs 2 at plain old 1080p (with all options maxed), I get GPU utilization of about 80% on both cards, not to mention it heats the house.
What OSI don't know.. I have two 1080's in SLI and running Watch Dogs 2 at plain old 1080p (with all options maxed), I get GPU utilization of about 80% on both cards, not to mention it heats the house.
Sli is junk for most games. Disable one card and you should see better utilization and similar performance. Besides at 1080p with all that gpu power, you are most likely bottlenecking your cpu.
Not true. When SLI is supported in a game, you'll get a very noticeable performance increase. That's the whole point of it.
I've been running cards in SLI for years and when a game is set up properly for it, you'll get a 50% to 100% increase in performance.
The real problem with SLI is that lately there are a few games that don't initially support it, which is frustrating. It seems eventually most end up supporting it via a patch, but not right out of the box.
Thankfully Watch Dogs 2 and The Division support it.
I too know about this. I have had 980tis in sli, 1070s in sli and 1080s in sli. In the end I preferred a single 1080. It was the most consistent high performance I could get across all my games. Sli support has always been sketchy and you are lucky if you get the scaling anywhere near 100%. Besides as I said you need to be running at least 1440p if not 4k in order not to bottleneck your cpu. 1080p is way too low of a resolution for 1080s in sli.
