please paint the whole car bronze no stripes no silver no orange.
bronzenist is bestest bronzemist is fastest!
That is the plan.... only way stripes would go back on, is if my old
SLP GTX hood would fit... otherwise, just looks stupid.
No yellow e85 gas cap?
Lames
Torque steer much?
Nobody cares about the stupid TR anymore.
Just passing along some observations/fixes for that same issue.
If someone had done the investigating/testing before me and shared the info then we wouldn't have a pair of fucked 400$ slicks.
Its a paint marker, vice grips, 7/8" wrench to add toe in to test... and set it back for the drive home/street mode
nice numbers i bet that cars a blast on the street
If it was turbo'd it would make like 700whp...
The TR suffered from the same fate. I fixed it by going to nearly three degrees of toe in so that when you floored it the car would go straight because the wheels would be at near zero degrees toe.
Now with the new all heim joint suspension installed it's far more stable at just .2* toe in on the street tires.
I haven't tried it with the Slicks yet but im hoping that it doesn't need more than 1* now.
After getting an alignment, balance, putting the front strut tower brace back on
and setting the AGX struts to 4 , its now much more controllable.
Before it was almost anything into boost was all stupid like... now I can
almost go WOT and keep it under control.
Little bit more work, and will be perfect street cruiser..
Got an alternator on order coming
Got some ground wires I wanna clean up while replacing the alternator
Change the lower idler pulley
Gotta do some research on fixing this belt slip. I want more and constant boost
Carbinite Metal Coatings
I had my new pulley done, but obviously the car isn't back together yet so I can't really report on how much it helps.
