I think 350 at the wheels would probably be pushing it pretty hard. Might not be able to keep up with the flow needed. Not 100% on that one though. [MENTION=53]Turbocharged400sbc[/MENTION]
If the pump is real close to being sufficient than I believe I could get a bit more output by driving it directly off the alternator which puts out 14.4 volts. I'm not versed on how to wire this exactly, I'd have to get smart on that. I've see the graphs on the difference, it's quite a bit. I know there are products like the Kenny Bell boost-a-pump but I'm on the zero money spent on hardware budget. And of course the pump will be under more strain and wear out quicker.
Oh and build a meth injection kit for it.
Look up FPR crushing. May get you a few lb/min. I will say I would spend the bread on a good in tank pump even if I cheaped out everywhere else.
Run a fat wire from the alternator to the pump (along the fuel lines is easiest). Splice in a relay that is triggered by the old power wire.
https://www.enginebasics.com/Advanced Engine Tuning/fuel pump relay.html
Also install a temporary fuel pressure gauge that you can see from inside the car (tape it to the windshield). Take a drive, go WOT and see if the pressure maintains or drops off at high RPM. If it doesn't drop off, you have enough pressure and flow. No need for more.
