So, Tacos notwithsdanding got the following things ready to go
Kilduff Shifter and Console
replaced passenger OEM seat with Corbeau Forza to match driver side.
Refreshed Strange S-Trac
3.25 gear, took out 3.50
refreshed the wiring on the two step and boost controller and transbrake
Refreshed CVS shafts and stubs with new bearings
Entire 9 inch pumpkin refreshed.
Solid Frame bushings
Refreshed QA-1s and mounting.
Refreshed the heads
Dumped the Precision 6266 Journal Bearing Turbos and replaced them with Comp 6767 Double Ball Bearing Turbos
Replaced the oil pump
Replaced several injectors that had gone bad
adjusted the plug, changed the heat range
Still looking to redo the roll bar and go to a 10 point or better cage and will need shute hardware.
last pass was 9.29 @ 154 before these changes. Looking for an 8 second pass when the weather cools down. We will put a few heat cycles on it and do some 60' chasiss and suspension work before the cooler weather.
Here are some pics of the console and the second Corbeau.
