So managed to pull the dashboard out last weekend and overall everything is in fairly good condition. Here you can see part of the mess of wiring that it came with. It was nicely tucked up but most of the wires weren't hooked to anything. The mess near the steering wheel is a temporary harness I made for lights/taillights etc.
Datsun-5 by
Mark Olsen, on Flickr
Datsun-4 by
Datsun-8 by
Clutch and Brake switch that I need to hook into. Can see the Hazard and and ignition switch also. These will be getting new hookups also.
Datsun-7 by
Dexter was curious about what I was working on, he doesn't like the race buckets though.
Going to try and get some pieces out to powdercoat and waiting on a bonus from work so I can pull the trigger on a stereo, hvac, speedhut gauges which should round out the basics for this car.
Hoping Satin black powdercoat will look nice on these.
Datsun-1-2 by
Been spending about 2 nights coming up with the diagram for a new harness using all the OEM switches as I want everything to look as stock as possible. Stock all of your power runs through the Headlight and wiper switches. I am working to redo that so it is all through a relay.
Ordered a lot of supplies from
https://www.corsa-technic.com/cart.php who are up in Wisconsin. Most of the connectors on this are also used on older japanese motorbikes so are still available. I made the choice to move to connectors for the dash that clip together as I still might track the car and vibration will knock anything apart if you let it.
Datsun-9 by
Cleaned up and regreased the headlight and wiper switches. Then had to solder some new wires where they were missing and where somebody had used wire nuts that ended up causing a fire. The whole inside of the dash was covered in fire extinguisher stuff. Air compressor and a face mask took care of that.
Don't use wire nuts.. please.
20170217_130204 by
New wire soldered on and new connectors crimped on
20170217_135358 by
New connector and the headlight switch is ready for another 40 years. Pull once for running lights/dash lights, 2nd stop is headlights on. Highs are a pull on the turn signal stalk.
20170217_135352 by
You can tell how much power went through these by how brittle they are from heat.
20170217_143814 by
Cleaned up the pins and in a new case.
20170217_143532 by
20170217_143532 by
Wiper switch ready to go. Pull one spot for low, 2 for high and turn it for wiper fluid.
20170217_144359 by
Also found a picture I took of the new fuel pressure regulator. Still need to mount it but will figure that out a little later.
Datsun-1 by
