injector install
P
PearlBlue L
anyone want to help me out with this. it seems pretty easy.
so far this is what i think all there is to do...
disconnect negative battery post
release fuel pressure from fuel rails
2 8mm bolts hold the fuel rail on
lift fuel rail from injector and make sure the O-ring comes out of fuel rail
unplug harness from injectors
pull injectors out
put new injectors in
plug harness
lube up new injectors before seating into the fuel rail
put fuel rail back on new injectors making sure it is seated fully
screw 2 8mm bolts back to fuel rails
build fuel pressure back up
could driving with 60# injectors do any harm if the tune is only for the 42# injectors?? it seems like if the tune is programmed to flow fuel through the 42# injectors that it would flow the same ammount through the 60# injectors untill i got a new tune to set the fuel flow higher. so the way im thinking is that if its pushing 42#'s through the 42#ers then its only going to flow 42#'s through the 60#ers and i shouldnt have any problems as far as anything messing up right? obviously i didnt get the 60# injectors just to keep the same ammount of fuel flowing, but im just saying until i get my new tune is it ok to drive with them in?
  • P
  • 2
  • 417
