Future modz, currently running a zzp downpipe with spun convertor
they're real. they're not on the car yet. still counts. if you have no valuable information to post, stay the fuck out of my thread. i don't shit on threads where you're asking for help. dick face.Lmfao you don't even put real mods in your sig.....wow
OK, I'm adding a flux capacitor to my signature.
What exactly is a 'spun' converter?
The Magnaflow spun catalytic converter is a compact catalytic converter design for use in tight places, such as on street rods or for custom car applications. Magnaflow fabricates each converter body from a single CNC-formed and laser-welded tubular section, which is then spun into a 4'' round converter body shape. Each converter is literally manufactured around the ceramic catalyst, securely tucked inside, and necks down to thicker gauge material at the inlet/outlet for maximum durability. Converters contain the properly loaded ceramic catalyst for optimum cfm.
It happens."High flow" I believe.
Its amazing the assbackwardsness of how s00ls does shit. If you would have got a tune like we all told you in the beginning before even doing the cat you would not be having any of these issues, would have passed emissions, and would have spent far less money.
<---waiting for "to each his own" and "i like to be unique" when in reality you just make bad choices.
This code originally happened in december after I had the new downpipe installed. installed o2 sim and it had a lean code, so when I put the o2 back in the pipe, this code came back. So I know it's the high flow cat for sure setting the code. It's tune time.Even with a brand new high flow cat, the rear O2 can set a below thresh hold or whatever code. Mine went off within days of putting a magnaflow cat in. If you had the same cat, DP, and rear O2 sim functioning fine before you took it apart, it's only logical to assume something you touched is the culprit.
***IMPORTANT information concerning High Flow Catalytic converters*******
The downpipes we sell come with a high performance converter. It is OBD2 compliant but it is on the very edge of being so. The PO 420 code is set when the rear bank O2 sensor PCM thinks that the converter is not doing a good enough job. Because the stock cat is so thick and dense, it can still function when the tune is off or it gets old. An error in tuning, running too rich, having too cold of a Tstat, too cold of plugs, or an old primary O2 sensor can all affect the engine enough to set a code when using the cat.
