Hood Pin Installation
black35thGT
Apr 9, 2006
89
hopefully im not too late on this, but im assuming you have an 04 from your name. my hood pins are installed where the factory hood adjusters were. the adjusters were removed and i put an extra nut on the pin (total of 3 on each) so that the hood can still be adjusted if needed. you need to cut a little bit of the support away from, but its not that hard. if you havent installed them yet, let me know and ill give you a hand if you want.
here a picture of the where theyre at, if you want/need a bigger one let me know. hopefully this helped you out.
ps: this is from like 2 weeks after i bought the car (bone stock). i havent had time to get any new pics since then, the headlights were swapped and its been cleaned up a lot since then.
  • -<SVT04>-
  • 2
  • 337
