If it's the same 8spd behind the 5.3 as the 2015 6.2s I'd have no problem getting one.
I hear it's not worth it. I don't know much about trailer brake controllers but my buddy who tows atvs in his enclosed said the aftermarket ones are better. But I do like the stock integrated into the dashHow many duckets do you have to spend to get the integrated trailer brake controller?
That is half of it, that location is sweet. I had heard the integration makes it better, but that might have been Fords... Not sure if I had heard the GM one was good or not.
On 14-15 the gmc the headlight projectors are the same for all tiers with a shutter for high-low beam in one projector. They suck at night if its raining its worse. I switched to a better Philips bulb which helped a little but not much. I run the fogs every time the lights go on. Wiring the fogs on with the highs helps some. I need to install these rigid fogs and hids I got two months ago.Exactly. I'm adding non signal tow mirrors from the aftermarket. Still power and still heated and about $300. The standard halogen housings on 14 15 Chevys are good. I see much better then the 55w hids I had in my trailblazer.
[MENTION=10447]crooks[/MENTION] what are you doing for oil change intervals? I'm still at 3,000 miles. I've seen some nasty build up on valves and dropped lifters on engines that follow "spec"
0 complaints on Ferd controller here.
I change it when it reaches 50%-30% on the dash its usually around 3-4k miles. Only use mobile 1 and gm filters. Ineed to get a catch can soon. Im at 33k miles
https://www.cars.com/vehicledetail/detail/646735819/overview/?aff=criteo&BAC=criteolf91814
5.3/4x4/double cab 44k msrp.... price of $29,475
