Genv install
Xtant12
3,318
67
Who put it on? They most likely rtv'd it and that's what's holding it down now, there are no screws that hold it down after the blower is off, but depending the the quantity of rtv you will probably need to pry it off
Ron Vogel installed it back in 2010 for me. Are you sure because I can see deep holes and I gave it some force and this thing didn't move at all. If your saying that the ic is held to the lower intake I'll pry it off but I want to be sure I'm understanding you correctly.
1quick
26,613
24,237
coal city
The deep holes are the ones the blower bolts should go through down into the lower intake, that or possibly the two halfs of the core use bolts to hold them together, I've never had to split one before, but yeah I'm betting he used a paper gasket and rtv to hold it down or just rtv, on my own stuff I rtv it and it's a bitch to take back off, you can text me some pics of the holes your talking about if you want but I'm 99.99% it's just rtv holding l it down and your going to have to pry it pretty hard if he used a lot of it, I've gouged the lower intake pretty good taking off intercooler cores that were rtv'd down if you get lucky he used a gasket and just rtv on both sides of it and it will rip the paper gasket apart making it easier to take off but a lot more clean up
Xtant12
3,318
67
Let's be clear, I am not an installer. With that being said, holy cap I can't believe how many things I had to remove to get the ic and lower intake out. Antifreeze everywhere, 2 bent prybar but I was successful. Tomorrow I plan to try to put everything g back on with the genV. And I have to replace a few ic lines. I got frustrated! Can anyone show me where the aluminum elbows go??
Xtant12
3,318
67
Xtant12
3,318
67
Well guys, Valiant effort but total fail. The car pisses antifreeze from the drivers side lower intake manifold. The baby will be here tuesday so the car will be down for a long time. I can't spend anymore time on this. Is there any 3800 installers around that could fix this for me?
10sec
25,951
5,837
I'm not sure how/why it could be leaking if you used the right gaskets. Just take it apart and put it back together using new gaskets, it shouldn't take but 1-2hrs max. Also, did you clean that coolant out of the valley and pour some oil down there to flush it out? If not, change the oil a couple times to make sure you don't have coolant mixing in. A spun bearing would suck ass.
10sec
25,951
5,837
Well you didn't tighten something, cause if you used the metal GM gaskets in manifold shouldn't be leaking. Just do like I said, take it apart and put it back together with new gaskets. Make sure you're putting in those "hidden" screws in the intake manifold, part of me wants to say you might have forgotten one. And when you get it off, get that coolant out of the valley so it doesn't get in the oil, and then run it (assuming you fixed the leaks) for 5-8min and change the oil again. Get some shit brand oil so you're not wasting expensive oil.
smug
8,091
3,778
Cedar Lake, IN
Dan Erickson
Pro tip: Use a shop vac and suck all the coolant out of the radiator and engine before taking anything apart on the engine. Put the vacuum hose right in the radiator neck or take the thermostat housing out and and suck all the coolant right out of the lower intake. Works great and it will keep spilled coolant to a min. Take the filter out of the shop vac before use or it will she soaked in coolant.
DanJ
33,568
16,929
That's what I always did. Never had coolant in the valley. Did you follow the gospel of James and clean up all the mating surfaces with some fresh razor blades before putting new gaskets on?
