Free-Flow XL lays down quick and helps keep a work area clean, that’s why it’s a favorite of racing teams for racing paddocks. To help keep your work area dry, the patented self-draining top and channeled understructure allows for maximum drainage and airflow. At 50% larger than the standard Free-Flow module, Free-Flow XL is compatible with all RaceDeck garage flooring.
The Key Benefits of Free-Flow XL:
High-End Style – Provides polished and professional look with a showroom finish without paint or decals
The Largest Self-Draining Garage Floor Module in the Industry – Fewer seams
Self-Draining – Maximum airflow and drainage of liquids and debris
Modular Design – Engineered to create a custom garage floor at virtually any size
Easy-to-Clean Surface – Resistant to petroleum products and most chemicals
Patented PowerLock® Technology – Flooring modules lock in place and stay engaged learn more »
High Performance Patented Diamond Substructure – Supports rolling loads of over 80,000 pounds while allowing air and moisture to escape learn more »
Compatible With All RaceDeck Garage Flooring – mix and match styles for a truly original, custom garage floorFree-Flow XL lays down quick and helps keep a work area clean, that’s why it’s a favorite of racing teams for racing paddocks. To help keep your work area dry, the patented self-draining top and channeled understructure allows for maximum drainage and airflow. At 50% larger than the standard Free-Flow module, Free-Flow XL is compatible with all RaceDeck garage flooring.
