But then you reinstall the o2 sensors correct? And the resistor and other thing just changes the electric current to make it think the cats are working?
Yeah cause if I understand right they test it by the temperature of the gases which then in turn they send a certain strength electrical signal off and I think the less it is the better it is? So if they put something into the lines that change it so the signal is less all the time it'd be making it think that it is working? Because I think the tests the cars run are to see if there is a change in the reading from the rear ones or something and that wouldn't prevent that it would just make the readings lower then they are the whole time?
