I was mainly giving him shit cause he is my brother
For routers and access points, I recommend Ubiquiti brand equipment.
Just not a fan of their CCTV stuff I brought up?
I like open platforms for camera systems. Cameras change so drastically that you want something future proof.
Ill take less convenience when you get better security, performance and updates.Likely something commercial and overcomplicated for your average Joe. Commercial grade equipment is great, but often comes at a cost and at an inconvenience to the non-techy as it generally will have less convenience (see: ease of use) features that the consumer grade stuff will have.
In my opinion, stay away from combos. You will have to sacrifice one of the two unless you pay an ungodly amount of money for something that just isn't worth it. For example, the modem might be great, but the router range sucks, or the router is great, but the modem sucks. On top of that, if the modem goes out, or the router goes out, you have to replace the whole unit.
You want specifics for each, or just what a modem / router do? I'll do my best to explain a modem/router in layman's terms.
A modem takes the coax signal from your provider and translates that into the internet for your PC. You want the speed of your router to be higher than the speed provided to you from the cable provider. For example: You have a 100Mbs connection from Comcast - you want at router that at least can handle 100Mbs (ideally more, to "future proof" yourself).
Comcast regularly is upgrading their speeds and if you have a modem that is faster than your current speed, you'll be fine if they give you more speed.
A router is a device that takes the signal from the modem, and "routes" it to multiple different devices, wired or wireless. Your modem will be plugged into the router, the router will then take that internet signal from the modem and distribute it to the different devices connected to it. A few things to ask yourself when buying a modem: How big is my house? How many users are going to be using the internet all at the same time? What will I be doing with my internet (Gaming, streaming netflix/hulu, web browsing, etc.)?
Let me know if you want more info (or if you were pulling my leg, I hate you).
Here's my list. Keep in mind that this is MY OPINION. I built this list based off of hardware I have heard of, read the reviews of, or more importantly used myself or for others that I have done basic installs and setups for. I have used every one of the 3 listed modems in customer's homes, but only the "better" router first hand.
Cable modems:
Good: https://www.amazon.com/dp/B00AJHDZSI/?tag=tcg21-20
This is the all around every day user. It'll be fine if you do browsing, gaming, hulu, netflix etc.
Better: https://www.amazon.com/dp/B00MA5U1FW/?tag=tcg21-20
This I would recommend if you're a power user or have lots of gaming or in-home streaming going on in your house (Plex for example)
Best: https://www.amazon.com/dp/B01N6SKK1G/?tag=tcg21-20
This I would only recommend if you're getting gigabit speeds, which most people are getting 150Mbs or lower
Routers:
The one thing to keep in mind for routers is house size. Even if you're not that heavy of a user but are in a large house, you might want to spend the money on a better router. Generally speaking, the higher end the router, the better signal strength it'll have. So if you've got a large house or multiple floors, get the better or best router.
Good: https://www.amazon.com/dp/B071J24FNY/?tag=tcg21-20
Same as above, good all around every day user router. Good for small-medium 1-2 floor houses.
Better: https://www.amazon.com/dp/B00R2AZLD2/?tag=tcg21-20
Same as above, good for heavy gaming or multiple devices streaming at the same time. Good for up to a large house, or houses that have devices in the basement and router upstairs or vice versa.
Best: https://www.amazon.com/dp/B00F0DD0I6/?tag=tcg21-20 or https://www.amazon.com/dp/B0192911RA/?tag=tcg21-20
These are your powerhouse routers. If you or your kids game and other people are watching netflix and you're trying to run your amazon tv or whatever - these are what you want to invest in. For most people, these are overkill.
Let me know if you have any questions!
I have the EdgeRouter ERPoE-5 for my router. Nice unit, not user friendly at all for a non-computer person.
Very powerful, very customizable, but the average Joe won't be able to get it working out of the box.
The average person can't even setup a modern Smart TV any more.
Let alone a prosumer level router + access point setup.
Thats when you hire a contractor to setup the system for you, and most people aren't going to pay those rates.
Why do you need a middle of the pack modem to run plex when plex is your in home server, which is more of the router's job?
Unless you are streaming from someone eleses server, but why not say Kodi?
Still rocking my 6141 for everything since all I get is 100MPBS down and thats pretty much what I pull with that and my current POS router.
Very easy. You just need to tell comcast the info for the modem and then you're done. That part took forever b/c comcast sucks but its easy enough.
WRONG, kind of. You can do that, but it doesnt always work. I tried the last time I updated my modem and the activation page refused to work...which resulted in an hour long game of waiting for comcast to answer the phone.
I was always under the impression you had to call them to provide the MAC and they'd push a new "config" packet for the new device.
