Oh and clear tail lights. Totally get those
Nice, should look and go good once its all fixed up. What bed liner did you use?
(Failure while towing cannot be an option)..
What are you towing that is so important? And if it is, why not buy a better rig to start with?
I thought you got rid of the ram because the transfer case was failing?
Eh, failure is an option if you are only towing a car. You pull over, call AAA, and go have a beer.
Rv plus is 100 miles......
And towing both cars with that?
http://www.trailerlife.com/wp-content/uploads/2012/01/Trailer-Life-Towing-Guide-1999.pdf
According to this the most you could tow is 7900 lbs, that is assuming it is equipped that way.
I just don't see it, your cars are light, but together they will probably weight 6k that leaves 1900 for the trailer and you are at the MAX.
These guys sell super light AL trailers and they weigh 2500 and cost a BUNCH of money: J&F Trailers - Aluminum 2-Car Hauling Trailers
I think you need a bigger rig, 3/4 for sure.
no, just the tip.
Bullshit, you just like to fix junk I think.
I just don't see it, your cars are light, but together they will probably weigh 6k that leaves 1900 for the trailer and you are at the MAX.
You just like to chime into everything?
it could be 2 miles, I still will need to call about the trailer stuff.
Fair enough, Like I said, that would be a long-term plan, so if it doesn't include the Expo, so be it (Years from now).
I was just letting you know it's 100 miles....no reason to be a bitch.
Why the F would you trailer the mini?
